Question about 2001 Dodge Ram 1500 Truck 4WD Front Steering Kit
Dodge ram compression troubles
Replaced plugs and wires still have troubles chugging along don't know what it is
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 180 Answers
Hard to tell with the limited info. How about a cap? Make sure you use original equipment plugs
Posted on Nov 25, 2013
While driving truck there was a popping noise, motor turned off . Distributor cap and rotor along with spark plugs and wires changed. Truck still won't start. 2003 dodge ram 1500 5.9 litre
5.9 aren't prone to this, But pull the distributor cap. Have someone crank the engine and watch to see if the rotor moves. Also put the number one piston on top dead center on the compression stroke (remove the spark plug to check compression side). See where the rotor sets compared to a diagram At top dead center.. Sounds like the chain broke (unlikely) or jumped.
Sep 08, 2014 | Dodge Ram 1500 Cars & Trucks
Random misfire dodge ram
Check spark plugs and look for crack or melted plug wire change cap rotor new plugs one might be cracked if already replaced also fuel filter might be plugged if still happening get Haynes book do spark test on cylinders and compression test to narrow down problem but try complete tune up first before assuming the worst k
Feb 21, 2013 | Cars & Trucks
2001 Dodge Ram 3500: brake lights don't come on, switch has been replaced and installed to instructions, turn, four ways, parking lights and cruise control interrupt all work. Is there a brake rel
have you checked wire harness @ rear of truck ? and along frame rail, ? and condition of the rear taillight assymblies, ? corrosion could be in these areas. check all ground wires also, not sure about relay ! don' t think so ! why would brakes need one ?
Feb 02, 2013 | Dodge Ram 250 Cars & Trucks
95 dodge van, 2500. has a BAD engine miss, seems to smooth out when going up hill (giving it some gas) gets bad again when just going cruise speed..
Well to start with, if you have a 1995 Dodge van and it has the original engine, you have a fuel injector for each cylinder. The last year Dodge used a carb was 1987.
So you could have injectors that are not working, or the plugs may not be firing because of the cap or rotor, or it could be a compression or vac problem.
I would want to know which cylinders and then go down the list of possible causes. You should be able to use a vac gauge or tach and pull one wire at a time to find the weak cylinders.
Feb 01, 2013 | 1995 Dodge Ram 2500
04' Ram 1500, bad mis-fire. cust repl s/plugs. no help. Codes for coils #7 & 8 w/mis-fire. replaced coils & wire set. Better, but still P0300. Compression good
You still have random misfires (PO300)
You most likely replaced those coils that set a code, and those were not the one bad offender,spiking the computer module.
Take a new coil and put in a cylinder,no change, replace old coil and move new one to next cylinder. You can do that once or twice a day, if you have nothing else to do. You need a 90 degree day, to really get that solved,unless you have an ignition oscilloscope.
Never had a bad spark plug in 45 years.
Sep 18, 2010 | 2004 Dodge Ram 1500
94 royal begis to cut out, chugs at about 55
Replace the spark plugs and wires along with a distributor cap and rotor. Be careful to leave the old wires and plug wires connected to dist.cap, just remove dist. cap from the distributor and lay aside with plug wires on it then install rotor then new cap and proceed to replace each wire for cap and spark plug one at a time so you don't mix up the spark plug wire firing order. Cap laying to the side is used for reference purpose.
Feb 26, 2010 | 1994 Oldsmobile 88
My dodge ram 1500 is missing on a cylender
ok check the plugs first replace if worn then the ignition wires replace as needed then have a pro do a compression test and look for broken valve springs or burnt valves
Sep 29, 2009 | 2004 Dodge Ram 2500
1997 Dodge Stratus, 2.5L 4 cyl engine. Engine diagnosis from a trouble reader = cylinder 3 misfiring. The plug and spark plug wire are good. I don't know how too test the electronic ignition or the fuel...
Test the compression in that cylinder. Make sure you have the correct plugs, and good wires, as well as the cap and rotor button. If you have good compression, and the plugs and all are good, I would suspect either a bad fuel injector, bad head, or a bad distributor.
Aug 12, 2009 | 1997 Dodge Stratus
I have a 2001 Dodge Ram 1500 5.2L, 197000km/120000miles. The cat was plugged up with no engine power. It occasionally smoked upon ignition. It occasionally smoked out an oily soot from the exhaust. The cat...
The plenum problem should not affect compression tests. It allows oil to get sucked into the intake and will cause carbon buildup, plug fouling, and pinging. If you have zero compression on a cylinder, it is usually a valve problem. Even a burned piston will make some compression, unless it has a big hole in the middle.
Sorry, but if your compression results are to be trusted (and it seems they are), then you have to tear a head off to find the problem, or at least get a borescope in it.
May 18, 2009 | 1999 Dodge Ram
2001 Dodge Ram 1500 Truck 4WD Front Steering Kit Logo
98 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
