My a/c does not stop even it reaches its desired room temperature
The motor continues to run even if the room temperature reaches to its level. I think there is a problem in the timer of the motor. Can you help me about this matter.
    Genius:
  • 1,198 Answers
Look for a 'power saver' option in the controls. It should turn the fan off when it is not cooling or heating.
Posted on Nov 26, 2013
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Furnace doesn't reach desired temperature
On the thermostat if its a manual on then pop the cover off and look for a small dial with numbers on it. Take and move it tpoi a higher number than whats it is set at. Its called a heat anticipater and is supppose to make it so that the unit does not oveshoot or under shoot like what your experiencing. If its a digital oine then you are going to have to configure the setting in the insdtallers menu.
Posted on Dec 21, 2008
  • 3 Answers
SOURCE: Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Posted on Mar 07, 2009
  • 400 Answers
SOURCE: lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Posted on Mar 20, 2009
Gree air conditioner
Check to see if your fan is in the on setting.
Nov 25, 2013 | Heating & Cooling
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
Can i set it to a temperature that will allow it to turn on and off automatically
Any temperature you set it at, the AC unit will turn ON and OFF automatically. Once the set temperature has been reached and held for 5 minutes, the unit turns OFF, but the fan may continue to blow for a few minutes. When the room temperature rises above the set level, it will automatically turn ON again and continue to run, until the set temperature is reached and it turns OFF.
I really hope this has helped you and thanks for choosing FixYa.
Jul 21, 2011 | Whirlpool ACQ158XP Wall/Window Air...
I need to know how to go about fixing the coolant fan to the radiator in a 1998 Ford Crown Victoria to keep my car from overheating every week.
The coolant fan run on its own when the temperature crosses a certain predetermined level. This is triggered by the relay. And it runs even after the engine stops till the temperature reaches the lower level. So, there is very little we can do about it. If we run it continuously then the fan will get burnt.
Dec 15, 2010 | 1998 Ford Crown Victoria
AC does not cool to the temp as desired
Does the thermostat have a mercury bulb in it, if it does you need to level the thermostat.
When you take the cover off, on the sub base there should be a couple of marks or grooves
One on each side of thermostat, you need to take a level and loosen the screws on the sub base
And with the level completely level align those two marks with the level.
If you don’t have a mercury bulb, then your thermostat may need the heat anticipator adjusted, some you can adjust the bi-metal coil, but I haven’t done that, so I couldn‘t tell you how to do it, or you just have a bad thermostat.
Apr 16, 2009 | Heating & Cooling
Lg split indoor fan runs non stop
Hello Hamid,
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
