Thid number is odd. it is greater than 45. it is less than 60
Pick answers from bag only which is 1 8 7 4
  • 7,993 Answers
The number is 47
Posted on Nov 28, 2013
What is code 60 on chevrolet malibu 2014?
  1. Ignition OFF. Disconnect the harness connector at the B60 passenger presence sensor.
  2. Test for less than 30 ohms between the low reference circuit terminal 2 and ground.
If 30 ohms or greater
  1. Ignition OFF, disconnect the X2 harness connector at the K36 SDM.
  2. Test for less than 2 ohms in the low reference circuit end to end.
₪ If 2 ohms or greater, repair the open/high resistance in the circuit. ₪ If less than 2 ohms, replace the K36 SDM. ₪ If less than 30 ohms
  1. Ignition ON.
  2. Test for 4.75-5.25 V between the signal circuit terminal 1 and ground.
Sep 29, 2016 | Chevrolet Cars & Trucks
Is 13/25 greater than or less than 1/2
If 2X the number on top is more than the number on the bottom then it's more than I/2.
Feb 02, 2015 | Office Equipment & Supplies
This mystery number has 4 digits.every digit is an odd number.none of the digits is a 9.every digit in the number is different.the smallest is in the tens place.the preceding describes two possible...
Odd numbers 1, 3, 5, 7
Uses all 4
1 is in the 10's place
7513 is the largest number that can be created
This is answer based on the provided information.
Jun 16, 2011 | Casio Office Equipment & Supplies
Three times the smalles of theree consecutive odd numbers decreased by 7 equals twice the largest one. find the numbers
The hardest part of a word problem is translating it into the equation or equations you need. This one needs just one equation.
Let N = the smallest number. Since they are consecutive, the next ones will be N+2 and N+4. (It doesn't matter that they are odd, just that each one is 2 greater than the one before.)
So, N = the smallest number and N+4 = the largest. Translate the problem (3 times the smallest, N, decreased by 7, equals twice the largest, N+4) into numbers:
3N - 7 = 2 (N+4)
Then it's simple to find N:
3N - 7 = 2N +8
3N - 2N = 8 + 7
N = 15
The three numbers then are 15, 17, 19. Check the answer by seeing if they fit the original problem. 3 X 15 = 45, 45 - 7 = 38, 2 X 19 = 38, so we got the right values.
Mar 06, 2011 | Office Equipment & Supplies
How to round off bill amount in invoice for e.g if the bill amount is coming Rs.2474.75 , and we want to round off 25 paise that means Rs. 2475 then how to do it
ROUNDED NUMBER IT A PROCCESS APPLY ONLY WHEN YOU ARE DEALING WITH SMALL NUMBERS LESS THAN ONE IN YOUR CASE SINCE THE LAST NUMBER IS .75 WILL BECOME 1 BUT IF YOUR LAST NUMBER FOR EXEMPLE IS .45 WILL BECAME 0 OR NOTHING IN ORDER TO ROUND A NUMER APTER THE POIN (.) must be greater then .4
Feb 19, 2011 | Refrigerators
Out of 1,3,5,7,9,11,13,15,17,19 pick up any 5 nos. to make a total of 50.
Several ways to do this. 1, 5, 13, 15 17 is one of them.
(1 x 5) + 13 + 15 + 17
Workings:
(1 x 5) = 5
5 + 13 + 15 + 17 = 50.
- You cannot add five odd numbers together to make 50. Five odd numbers added together will always be an odd number.
- You cannot add four odd and take an odd number away as this will also total an odd number.
Therefore 2 of the numbers must be multiplied as this enables you to effectively add four odd numbers together to total an even number.
Hope this helps. Got any more?
Jan 13, 2011 | Vacuums
When I substract log(2) from log(4) I get .301029957, the answer should be 2, what is wrong?
The answer for the problem log(4) - log(2) is actually 0.301, so the good news is that your calculator is working properly! Here's a quick breakdown of the solution for the problem:
1) We know that log(x) = N means that 10^N = x. So in this case, we need to find a number that 10 can be raised to in order to get 4 and 2.
2) To get a better idea of what the answer to the problem will be, we look at the scale of the numbers. 4 and 2 are both smaller than 10. In order to raise any number to a power and get a smaller number, that power must be less than 1. If the power was 1 or greater, the answer would be more than 10. Therefore, we know that log(4) is a decimal less than 1 and log(2) is a decimal less than 1.
3) Now we'll simplify the problem. A logarithm rule states that:
log(x) - log(y) = log(x/y)
We can use this rule to simplify the equation in the problem.
log(4) - log(2) = log(4/2)
Since 4/2 = 2,
log(4) - log(2) = log(4/2) = log(2)
4) Now to solve the equation, the only thing that must be calculated is log(2). This would be done on a calculator. In step 2, we analyzed that log(2) must be less than 1. Therefore, the calculator is correct with the answer 0.301.
Hope this helped!
Nov 30, 2010 | Texas Instruments TI-84 Plus Calculator
1111 base 2 + 1010 base 2 my answers are either 20 or 30
You can solve this the same way you solve regular base 10 addition. In base 10, if you add two numbers and the result is greater than 10, you carry a 1 to the next column to the left. So 6+3=9 (no carry), but 6+5=11 (we carried a 1 to the next column).
In base 2, there are only 2 digits to use (0 and 1) and we carry when the result is greater than 2. So in base 2, 1+0=1 (no carry), but 1+1=10 (carry to the next column).
So to do your addition:
In the 1's column, 1+0=1, no carry
In the 2's column, 1+1=0, carry 1 left
In the 4's column, 1+0+1(the carry from before)=0, carry 1 left
and so on.
It's easier than base 10, with only two digits to deal with.
Feb 03, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
42 people viewed this question
k24674
