Question about Pentair Pool & Spa
250 lp heater stops and starts - Pentair Pool & Spa
    Champion:
  • 305 Answers
Standing pilot heater or electronic ignition???? could be a result of many diff things......gas valve coils could be shorting out....an electrical short somewhere.....safety is opening/closing
Posted on Dec 05, 2013
I have a Jandy XL 250 the exchanger was sooted up the burners were disfigured from overheating so ive cleaned the heat exchanger replaced the burners and the front panel still gets very hot after about 20...
flame should be blue, this sounds like a natural gas unit (orfice) running on LP. Lp is burns hotter than nat. and will burn orange. and use huge amounts of fuel.
Aug 10, 2013 | Hayward 250kbtu Ng Pool Heater - Inground
I have a 2008 F-250 when the heater is on and the truck is stopped or driving under 15 MPH the heater blows cold air, if you speed up it starts blowing hot again. What could this be?
Could be low coolant, could be a bad head gasket or other point where combustion gasses are entering coolant.
The heater core fills with bubbles, it's commonly the highest point in the cooling system. When the motor is turning slow the water pump isn't moving enough water to force the bubbles to go on through the heater core but when you speed the motor up the pump is able to force the bubbles down to the motor. They'll go to the top radiator tank and then out the pressure cap to the recovery tank. Look for bubbling in the coolant recovery tank.
lp
Dec 29, 2010 | 2008 Ford F 250 Super Duty 4WD
I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Nov 29, 2010 | Desa International GWRP16 16,000BTU LP Gas...
Heater will not fire. Fan comes on for a few seconds & shuts off. code on control panel is AIR FLOW SW. Heater worked fine until Sat. delivery of LP.
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Jandy Laars Lt 250,000 Btu Heater
I have a 250SX aquastar Bosch tankless hot water heater . It keeps going out on EC code; whats wrong? Also I've been running the unit for about a 9 months without hooking up the condensate dain line.
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
Pentair minimax 250 leaks onto burner
Unfortunately it is usually caused by a bad heat exchanger. Not too expensive, but a dirty, time consuming job to replace.
Aug 09, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair 250 CH LP will not ignite. Pilot works
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pool & Spa Logo
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
