Question about Dryers
Kendal fan/light remote UC7208T doesn't dim
The remote has 3 fan speeds, and that works. But the dimmer control either sets the light on or off, there is no middle ground.
  • Michael Hornstein
    Michael Hornstein Nov 26, 2013
    The light on my fan is a G9 Halogen bulb. I suspect that the 4 dip switches are not in the right places, but there is no reference manual
    Genius:
  • 1,617 Answers
If you have CFL bulbs they won't dim. There should be a switch to change remote from CFL to incandesant light inside the transmitter. You'll have to match settings with settings in receiver.
Posted on Nov 26, 2013
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
jfpogie
  • 104 Answers
SOURCE: dayton 24 inch two speed fan
yes, it will work and not damage your motor.
Posted on Jan 28, 2008
jmgldsmth
  • 1869 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 6 Answers
SOURCE: I have 2 Remote Control
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Posted on Jan 24, 2011
  • 34763 Answers
SOURCE: Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Posted on Oct 08, 2012
Where to order remote control for my ceiling fan no.uc7130t
from the service dealer / authorized service agent for your brand of fan
Oct 25, 2015 | Westinghouse Televison & Video
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
Kendall wall mount remote Model UC7208T instruction for reverse
on the top of the fan is a switch - just slide it to the opposite side of where it is and it will operate in the opposite direction when you restart the fan
Mar 16, 2012 | Dryers
I bought a Hunter fan Model 21778 that uses 2 incandescent candelabra lights. Before installing it I called Hunter support to see if it was okay to use a dimmer switch for these lights (I had already...
They're right, you don't want to control the whole thing with a single incandescent dimmer. First of all, the fan-speed and the lights will all be controlled by the same dimmer setting (dim low, low fan-speed - dim high, high fan-speed) - and the dimmer's not rated to control fans anyway which can result in exactly what they said.
There is a Skylark control, the S2-LFSQ- where half the knob controls the light, the other half controls the fan. The only problem you may (and most likely) have is that in order for that to work, between the electrical box for the dimmer and the fan, there needs to be seaparate wire run for the fan, and a separate wire run for the light so that the dimmer can individual control both.
If that's a problem, I recommend the MA-LFQM-, which includes a module that you install in the ceiling with the fan. The wall switch it comes with speaks to that module, and gives you independent control of the fan and light without having to install new wiring. I have one of those myself, I've installed one in one of my friend's houses, and they work pretty well and then you don't have to worry about what wires you've got in your wall.
Jan 19, 2011 | Lutron Skylark Incanhalogen Dimmer 600w ...
Wiring Question
No, the way the motor speed control works is different from the way a light dims. If you connect it, it might work for a while, but it will either burn up the dimmer or the fan motor.
May 14, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
Dual Dimmer / lights go off when fan not on high.
I'm not sure of the exact wire arrangement, but it appears as though a fan and light wire are mixed up, as thought the lights are feeding off the fan wire. Its possible that in the switch box or even in the fan box the output of your fan is tied to the lights so that when the fan is at it's highest output (maximum current), yours lights work properly and not at any other setting. Check wiring for errors.
Dec 25, 2009 | Hunter 52" Ceiling Fan With Light And...
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Dimmer or not?
Are you saying you have a dimmer for the fan light and it does not work, or you do not know if the fan came with a dimmer switch?
Most of these fans have two switches; one is for the fan speed(usually three speed) and the other is for the lights(on -off). Adding a Remote control , which is optional for this unit , will allow for remote speed control(variable or three speed), and light dimmer control. The remote controls can be purchased in your local Home Depot or Lowes store. Hope this helps....
Jul 12, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Possible remote control problem
Have you tried holding the dimmer switch for 16 to 20 seconds?
Oct 21, 2007 | Hunter 20531 Vista Brushed Nickel Ceiling...
Dryers Logo
588 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
