Question about Car Audio & Video
I have a kenwood stereo and the diplay is reading Protect what do I do? I have the code and it gets approved everytime then just diplays protect right after.
    President:
  • 272 Answers
If you have a model with a detachable face there is a reset button under the face. Reset back to original state. If that doesn't work some of the older Kenwoods defaulted to the protect screen whenever there was a 'fault' in the system. ie. a shorted wire or blown speaker.
Posted on May 08, 2009
On my stereo kenwood kdc-w4537u will read protect what is the code to remove it?
The indication of Protect means that the amplifier of the stereo has encountered a serious fault and so is shutting down to prevent further damage. So this can be a damage on the hardware and so must be checked physically and replaced,. Normally the outputs or the power section can short and so result in the indication.
May 06, 2011 | Car Audio & Video
My kenwood car stereo model no. KDVMP5343U is showing protect while switching on
PROTECT (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
Good luck with it
Mar 27, 2011 | Kenwood Car Audio & Video
My stereo says" protect" everytime i turn it on. can't get anything else.
Hello grammagrisbo, hi your Kenwood head units will show "protect" when there's a problem with the speaker outputs so check to see if the impedance load meets your radio, 8ohms or 4 ohms?. having parallel two speakers on a single channel may cause this dilemma. This might also mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back to normal, the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do something to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. power it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker only. Turn it on again and see if it will displays "protect" message.
If the radio works with one speaker connected, connect the other speaker to the second channel, you may have now the idea where the problem begun, you will identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that channel.
If it displays "protect" with a single speaker connected, then disconnect that one and try the other one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit.
Aug 31, 2010 | Kenwood Car Audio & Video
My car stereo isn't working and on the diplay it says the word SA
the radio is lookin for a code. vw i assume. need to contact dealer if there isnt a code card in the glove box. usually 4 or 5 digit code
Feb 04, 2010 | Car Audio & Video
Kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
Jul 23, 2009 | Kenwood Car Audio & Video
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Protect mode
It has a fail safe. maby your battery is bad or its over-heated. have you considerd buying a new one? pleas send me more info about this problem
and maby i can find a better solution.
E-Mail me at Trekkiekid@yahoo.com
May 21, 2009 | JVC HX-C6 Shelf System
My kenwood car stereo says protect how do i fix this
well that means you had a safety stereo in the beggining and you proly didnt put the safety code in so it went into secure mode it to prevent the device from working if stollen
Mar 08, 2009 | Car Audio & Video
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood stacker system stereo
your speaker output is shorting either at the output terminals or at the speaker input . check the cabling . it will solve the problem
Feb 22, 2008 | Kenwood HTB-205 System
Car Audio & Video Logo
516 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
