Question about Electrical Supplies
Can I run Welders Of A Onan 30 kw stand By Generator
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
Depending on what Onan 30KW you have it maybe possible. If it was intended for residential use than no, it does not have the right alternator insulation class, or PMG style alternator. Also what size welder amps? Is it 1 phase or 3 phase. Let me know Onan model and I can advise better
Posted on Nov 25, 2013
5 Suggested Answers
  • 5 Answers
SOURCE: generator 30
fuse are meant to protect the costlier part of the machine thereby damaging itself.  there is probably overloading of your circuit. call the electrician and find the actual power required by your house.  there is a possibility of having a short circuit in your generator. your local electrician can check it.
Posted on Jan 24, 2009
mamicheddy
  • 79 Answers
SOURCE: Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Posted on May 09, 2009
  • 52 Answers
SOURCE: lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Posted on Aug 30, 2009
SOURCE: RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Posted on Mar 15, 2011
Searching for onan Model 45BGDFB30502 manual
You will be looking for a 4.5 KW BGD manual. Here is a link for the service manuals. One is from Spec A to G and the other starts at spec H.
http://www.scribd.com/doc/71647660/Onan-BGD-NHD-Service-Manual-BeginSpec-H-Pg-1-50#scribd
http://rich.homeunix.com/gravely/engines/onan/all-manuals/965-0529.pdf
Feb 08, 2016 | Electrical Supplies
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
Onan 12.5 JC-3CR
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Mar 02, 2013 | Onan propane generator set, 15.6 kva, 12.5...
Wiring diagram for onan 12.5 JC-3CR generator
Did you ever find a schematic? If not I can probably help you. Question is how do I get it to you :)
Onan 4 ky generator quits when a/c is turned on? Has no other load on it.
Is your generator 4 kW or 4000 Model 5500.
If 5500 as on the picture over your question the reason may be short in the receptacles or low voltage/ rpm.
If 4 kW MicroQuiet, there the reasons may be too much, that you will nead a troubleshooting manual.
Jun 14, 2010 | Watts Onan Portable Generator - 4000 ,...
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Feb 11, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
76 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
