Question about Dual Ford F250 F350 Crew Cab 04-08 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
Truck wont start when i jump out new starter
I charged batteries changed the starter and it wont start from key or if I jump out the starter solenoid
    Genius:
  • 1,198 Answers
I presume it will crank over, jumping the solenoid. If not, you got a bad starter. If it cranks over but won't run, you'll have to go down the list, spark, fuel, timing.
Since it sounds like you only changed the starter, maybe some wire to the ignition or fuse box is still off, hiding.
There's always that hidden impact switch, which disables the fuel pump in a collision. They like to hide that one.
Posted on Nov 26, 2013
1991Buick Riviera wont start has dash light but starter won't kick over unless you jump the solenoid
check for power from the ignition switch to the solenoid. probably turned off by the immobiliser
May 03, 2015 | Cars & Trucks
I have a 99 suzuki srad 750 that wont start once hot, ive changed batteries,stator,and starter,still wont start without a jump start
Did starter include a new solenoid? However, there has been a rash of bad "new" solenoids. Try to "jump" around the solenoid to see if it spins the starter motor. If it does, most likely a bad "new" solenoid.
Apr 05, 2015 | Suzuki Motorcycles
Car wont start
If battery is good, and you have a solid clean connection of the negative and positive, and car will not turn over, the next check would be the starter.. You can check if the starter is good by jumping the small wire (Solenoid) to the large wire on the starter. Just briefly touch the two together with a short piece of wire. If the starter roll, then you have a problem with the ignition circuit.. The starter will have a large lead running directly from the battery, what activates it is when you turn the key and the solenoid engages and make the two connect. When you jump the two you are bypassing the ignition key circuit and solenoid
Could also be a bad solenoid, this is usually the first to go bad on a starter and can be changed.. .
Apr 06, 2014 | Ford Escape Cars & Trucks
It won't start: new battery, have lights, it just clicks when you turn the ignition switch
you mean it wont crank, it must crank to start.
1: bad starter system
2: weak battery even a new battery can be weak.
if you dont charge it first.
or if it starts ok then wont later, that means cars charge system failure.
can you jump start engine? with jumper cables.
that be a big clue there, proving starter works but battery was weak.
if the battery is fully charged.
you can hot wire the starter solenoid, (tiny terminal)
if car cranks now, the key start wire is failing.
A/T or M/T tranny? both use different path here....??????
if you cant hot wire it, then that means the stater is bad
the cables bad or the battery is not really connected.
or possible the engine is seized, can you hand turn over the engine at the front crank bolt (CW , facing rear, in neutral)
if not motor is seized.
some times even the starter and rig gear can be seized.
the starter can be bench tested. too.
http://www.fixkick.com/nocrank.html
Sep 19, 2013 | 1988 Suzuki Samurai
When i turn the key the escape wont start it just makes a clicking noise?
That noise is probably the starter solenoid rattling because the battery charge is low. Start out with a jump or make sure the battery is fully charged up.
May 21, 2010 | 2002 Ford Escape
Car wont start
Does the battery have enough capacity to turn over the engine though? Even flat car batteries will still power the radio. The best way would be to jump start the car uing a set of jumper leads. If it starts you know it is the battery that needs replacing.
If it still wont turn over then it is most likely the solenoid in your starter motor. You can often tap the starter motor with a hammer and free the solenoid as a temporary fix. The starter motor is loacted at the back of the engine on the bell housing if rear wheel drive, or around the tranmission if a front wheel drive.
Jul 25, 2009 | 1998 Ford Contour
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Sep 16, 2008 | 1995 Ford F150 Styleside Regular Cab
Dual Ford F250 F350 Crew Cab 04-08 Boss 12" Phantom Sub Box Ce1250m 1250w Amp Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
