Insignia tv light is flashing but wont turn on
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 26, 2013
3 Suggested Answers
John-INSG
  • 312 Answers
SOURCE: insignia flatscreen won't turn on
Your TV should be repairable. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Posted on Mar 25, 2010
SD Tech
  • 14553 Answers
SOURCE: my insignia tv wont turn on but the blue indicatior light comes on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_21_2012_2_43_09_am.jpg5_21_2012_2_43_32_am.jpg
Posted on May 21, 2012
Insignia tv wont turn on flashing red light
Open internal fuse or power supply failure
Feb 10, 2018 | Insignia Televison & Video
Direct Tv mini caused my Insignia tv to freeze and now tv wont turn back on
The direct mini did not freeze the tv. It's a coincidence. Your TV needs repair. Unfortunately insignia tvs have a reputation for problems like this.
Aug 13, 2016 | Insignia Televison & Video
My daughter turned it off and now it wont turn back on
Now the tv LED power light indication is flashing?Yes.Tries tv unplug,replug back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If tv have same result problems or again later on.The tv power supply board is the causes and the problems,that the board where the power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 21, 2011 | Insignia 42" LCD Flat-Panel HDTV
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia flatscreen won't turn on
Dec 24, 2009 | Insignia IS-LCDTV32 32 in. Television
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
did you try calling the (877) 467-4289 Insignia help line?  I think they're open 24/7.  They just solved another Insignia problem for me.
May 13, 2008 | Insignia LCDTV26 26 in. Television
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
