Question about GE Advantium 120 Convection/Microwave Oven
Microwave turns on when door closes - GE Advantium 120 Convection/Microwave Oven
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Magic Chef MCD1311ST Microwave Oven
Turns on when door opened
this is dangerous; replace or adjust your door switches the interlock switches should only allow you to turn on the microwave when the door is closed
May 29, 2009 | Jenn-Air JMC8100 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
When door is closed, light and fan comes on
The Problem you Having is dirty Door Switches,Get some Electronic Contack cleaner from the Hardware Store,Make sure it has the little straw to Extend the Spray,Open the Door of the Microwave Look at where the Door Closes youll see Tiny Micro switches,*Note UNPLUG POWER FIRST
Jul 25, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
51 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
