Question about Logitech Z-340 Computer Speakers
No sound from speakers
Nothing will play out of my speakers. when i go to the control panel, it just says that there is no hardware installed. they are plugged into the computer and power supply.
    Sergeant:
    Champion:
  • 255 Answers
Have you check the driver for you audio card in your computer?if not, update.or you wil need a separate audio card for this.check first the connection for proper fit of the plugs
Posted on May 08, 2009
I was deleting things in add remove hardware and now my logitech x 240 speakers have stopped working, i also had a yellow ? appear in device management but i have downloaded something that seems to have...
There are two possibilities here which may be causing your problem.
Either you have not gone back in and enabled sounds in the control panel or you need to reinstall the speakers in the hardware manger and set the options to use them. That is "if" you have not deleted your sound card drivers?
to enable sounds, go to control pane, and then sounds and double click on it. Check to see if there is a sound sceme chosen (i.e. windows default). If there is no sceme chosen and its greyed out, click on the arrow and choose windows default and save it. It will tell you that your previous sceme may be lost if not saved first and ignore that warning - just continue.
Click the test option next to the sceme chosen and see if you can hear it?
If not, then continue troubleshooting and move to the next possible problem which is reinstallation of your speakers through the hardware manager.
Go to the control panel and find install a device or hardware manager (depending on which version of windows you are using). click on it. Windows will try and find the device you wish to install, if it locates the speakers then great just follow the prompts until installed. Then make sure the sound it turned on as indicated above and your done!
If it does not auto find the speakers you want to install, change the options to locate the item you wish to install yourself. Scroll the manufacturers drivers that came with your version of windows and find Logitech and the type of speakers you have which you want to install.
then follow the prompts to install the speakers. You might want to go back into the sounds icon in your control panel and check the optional tabs to make sure the type of audio device you are using is also the chosen default in your pc. (i.e. headphones, desktop speakers, or surround sound system ect.)
Mar 20, 2011 | Logitech Computers & Internet
A sound appears to play but nothing comes out
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 28, 2010 | Logitech S150 2 Speakers
No sound
Go into your sounds settings Control Panel> Hardware and Sound (on Xp its just sound)> sound> You should have 4 types of speakers available. I have Digital Output Device (HDMI) Speakers Realtek Digital Output Realtek HDMIOutput my default was the HDMI and i changed it to speakers and then my speakers worked.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 26, 2010 | E-Machines T3504 PC Desktop
Logitech
1.
Lets start with the obvious. Make sure the volume mixer control is not muted. This is usually a speaker icon at the bottom of the screen. If you do not see this then go to control panel, sounds and audio devices, and make sure nothing is muted.
2.
check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 09, 2009 | Logitech X-530 Computer Speakers
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
SOUND is not played during the function of any audio/vide players
  1. You need to visit the logitech web support page and download the driver for your model number at www.logitech.com allow it to install and then restart your PC.
  2. If this fails to sort it out try going:Control Panel>Hardware & Devices>Device Manager you may see a yellow triangle at sound controlers, right click it then click Drivers [tab] then click "update driver"
  3. Restart you PC
  4. Check all conections are good
  5. Try a different set of speakers to see if the fualt is with the speakers or your computer.
Jan 15, 2009 | Logitech X-530 Computer Speakers
I HAVE NO SOUND ON MY GATEWAY GT5660E. i HAVE TRIED EVERYTHING
Do you have the speakers plugged into the correct plugs in the sound card? Make sure speakers are not plugged into the mike jack. Do you hear any static as you remove and replug the jacks? Do the speakers have a power light?
Open Control Panel ->Sounds and click on Sounds tab. Do any sounds play? Click on the Audio tab and make sure Default device is your sound card. Click on Volume tab and then Advanced. Make sure nothing is muted.
Assuming you have Windows, check the sound card in Control Panel->System, Hardware, Device Manager. Check for correct drivers. If necessary, uninstall sound card and let Windows detect it again and install drivers.
Sep 16, 2008 | Audio Players & Recorders
Speakers will not play
hi!good pm...hope this will help...
check if your speaker is connected in the green socket of your sound card...check the sound card driver,reinstall if needed...check the device (start>control panel>system>hardware>device manager>sound,video & game controllers)...is the device working properly?if yes but still your speaker will not play?...try other speaker if you have...or replaced it...
Feb 08, 2008 | Logitech R-10 Computer Speakers
Help needed for speakers
lo-ve stated: but i cant still get to it in my windows system1.gif and sound options. But there's nothing there.
If there's nothing there your computer can't find a sound card!
blue
Feb 06, 2007 | Creative Labs Inspire 2500 Computer...
Logitech Z-340 Computer Speakers Logo
207 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
