Question about Brookstone HDMI Pocket Projector
Its not charging
I bought 1 last week and It work well but yesterday stop working looks like its not charging I dont know whats the problem is what can I do
Out of control revo 3.3
your receiver battery is low or check to make sure servo is working..if its working then its a low battery
Jul 16, 2013 | Traxxas Rc Revo Nitro Monster Truck
New alternator and battery, but the battery is not charging so car dies and wont start what do I need to check next.
bad conection. need to change batt posts on car or it dont have a good ground. follow the neg wire n check that one too.
Mar 01, 2013 | 1997 Ford Taurus
Odometer, tachometer, speedometer, and gas gauge suddenly stopped working.
Sounds like the body control module has gone bad. It has a relay that caries considerable current to all of these accesories and wears out.
It can also be a solder joint on the circuit board where this relay mounts.
Hope this helps, Robert
May 16, 2012 | 1995 Buick Regal
I bought my phone last week tat time the battery was working fine .The battery gives back up for like 3 days .But past 2 days i need to charge my battery every night and if i dont charge the phone gets...
There are two things you have tto check. 1. Your charger is perfect-check and replace it. And secondly, don't keep continuing in charging after you get indication of charging completed, remove charger.
Jan 03, 2011 | Cell Phones
No charging freezer
you have a one year full warranty and sounds like the compressor is not kicking in and you need to call and set up a service call cause if you work on it yourself it can void your warranty / larry
Mar 16, 2009 | Refrigerators
My ignition fuse keeping blowing
You have a wire rubbing on something metal. Look at the wiring harness in the car and engine compartment. Try moving them around a bit and see if you can get the fuse to blow or not to blow.
Jul 19, 2008 | 1999 Pontiac Sunfire
Cant call or receive calls!
hi,
if you take the phone back to the shop you bought it rom they should fix it.
Mine was doing the same thing so i took it back last week. Picked it up yesterday and it seems to be working fine. Guy said there is a software fault with these phones...
Feb 17, 2008 | Samsung SGH-U600
Brookstone HDMI Pocket Projector Logo
57 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
