Satellite Manuals echolink EL1444 - Audio Players & Recorders
How to put biss key in echolink 7555 extra
Jan 20, 2017 | Televison & Video
I need the code of echolink satellite receiver to set in remote control
Check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
May 22, 2014 | Televison & Video
Echolink test reports UDP 5188 and UDP 5189 indicates no receive.
In South Africa there are a few USB (HSUPA stick) dongle's (laptop/notebook) modems available where some work and some don't. I use 8ta (Telkom) which doesn't allow access to UDP 5188 and UDP 5189 yet the CellC dongle USB modem, allows access to Echolink. Two different ISP. 8ta use the Huawei Hilink (E3131) dongle where Cellc use HSUPA ZTE Corporation stick. I cannot comment on Vodacom as I do not use their facilities! Something to consider. At least I now have access to Echolink - albeit having to use a different 'modem'.
Aug 19, 2013 | Computers & Internet
I need the remote code for receiver echolink
echolink EL-700 FTA receiver unlocking code please solved it ?
Sep 24, 2009 | One For All URC-7555 Remote Control
I can no longer connect to Echolink
How to set up the ports for Echolink:
  1. Go to this page (link).
  2. Choose the correct router model (if you don't find it, use a model similar to yours. The setup for all Westell routers is almost the same.)
  3. skip the advertisement on the next page (upper right corner)
  4. choose "Echolink" from the list.
  5. Simply follow the instructions.
  6. Voila!
In general:
  1. Important!! (and most often the reason why it is not working): Make sure that yourWindows Firewall is not blocking the application (see Control Panel-> Windows Firewall -> Exceptions) (details also here).
  2. You have to allow UDP destination ports 5198-5199 between Internet andPC in both directions and allow TCP (source port any, destination port5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help.
Thanks for rating!
Mar 24, 2009 | Westell Wirespeed VersaLink...
How to set UDP & TCP port for Echolink
First I assume that you simply posted this under "Linksys > WRT" by mistake and you are using a D-Link router.
  2. Choose the correct router model (almost at the end of the page)
  6. Voila!
In general: Make sure that your Windows Firewall is not blocking the application (see Control Panel -> Windows Firewall -> Exceptions) (details also here). You have to allow UDP destination ports 5198-5199 between Internet and PC in both directions and allow TCP (source port any, destination port 5200) from PC to Internet.
If you have any more questions, just come back and leave a comment - I am happy to help!
Mar 21, 2009 | Linksys Wireless-G WRT54GS Router...
I have a problem with echolink connecting via the Dlink 624
do port forwarding in that you get it in the modem or router any if the port forwading option is there or not
Jan 27, 2009 | Computers & Internet
Opening ports
Echolink uses UDP protocol, you sure you're not opening ports for TCP protocol? There may be other ports that need access as well, google "echolink firewall rules" for more help.
Mar 11, 2008 | Siemens SpeedStream 2604 Router (obss2604...
Open ports for echolink
Hello Paintah, The link below has a complete walkthrough of enabling these ports!
http://www.portforward.com/english/routers/port_forwarding/Westell/A90-327W15-06/Echolink.htm
Cheers!
Jan 11, 2008 | Westell Wirespeed VersaLink...
 Grubhead
Grubhead
