Is it a temperature-controlled fan? I've seen some cars that run their fans for a few minutes after the car is turned-off, to cool-down the engine. After a few minutes, it will automatically shut off -- it also shut-downs when the "target" temperature is reached.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Try running it on a hard flat surface and see if it runs better. The shutting down could be due to the machine overheating due to poor airflow. Try cleaning the air vents around the case, make sure they are not dusty.
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
The problem most likely a thermal overload, the CPU shuts down when it over heats and will not boot up again until it has cooled down. If this problem is not fixed the the CPU will eventually fail. This problem is usually caused by a faulty CPU fan. Replace the faulty fan and remove the dust from the heat sink
You might have a broken or dirty CPU fan. The CPU heat sink fan is responsible to cool down your CPU while it is on. If it is broken or stuck(dirty), then your machine will power off automatically preventing CPU damage or worse-case-scenario:FIRE caused by "burnout".
Your CPU heat sink might not be mounted on your LT properly. Also causing overheating; thus shutting down.
Its a laptop right ? Right! Another thing you could try is to unplug the battery, and let it run from AC power only and see if it makes any difference.
