Magic pak furnace blower not working - Heating & Cooling
2 Suggested Answers
  • 207 Answers
SOURCE: i have a magic chef
u may have a bad ignitor or u might not have hooked up a safety switch or u may have accidentally caused a sensor to go out not knowing but it sounds like the ignitor is bad is it a glow plug or does it spark to light
Posted on Feb 26, 2010
I need to find replacement parts for a Magic Chef propane furnace model EG6E80. How can I cross reference them with other brands?
good luck, what parts do u need, most of them can be re placed with other furnace name brands, like ignitor, blower motor, gas valve, pressure switch, ignitor board, transformer, ventor motor, they have replacement for all those parts, remember most companies use the same parts
Dec 16, 2015 | Heating & Cooling
Thermocouple hard to remove on magic chef furnace
THEY EITHER HAVE A NUT THAT HOLDS THEM IN PLACE OR EARS THAT STICK OUT AND HOLD IN PLACE. IF EAR TYPE GIVE IT A PULL STRAIGHT DOWN IT SHOULD COME OUT
Mar 26, 2014 | GE Furance Blower Motor 1/5 Hp 208-230v...
I would like to install central air to my magic chef furnace what size unit i need also is the blower motor big enough to a house 1,520 square feet.
Hi manny factors are involved but a 3 ton system with at least a 1/2 hp blower (in high speed) should get the job done...
Jun 10, 2011 | Heating & Cooling
The furnance will not come on
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 03, 2011 | Raypak Converter, N To P Mv 105a - B/Pak
Our Armstron (magic Chief) oil furnace keeps shutting on and off during the heating cycle.
I will try to help, but a little more info would be great, when you say it shuts off, it is important to determine if it is the burner or the blower that is shutting off.
If the burner is shutting off and coming back on, the safety "fan and limit" control is getting to hot,,
If what I have listed above, there are several things that can cause it;
1. The first step is to make sure that the air filters are clean, the return air grills are clear, no objects covering them.
2. This part needs to be approached with care, Turning off power to the furnace is a must; then clean the blower area, and if it is a belt driven blower setup, inspect the belt, looking for cracks on the surface that makes contact with the pulleys. If the belt is old, it may be stretched and slipping on the pulleys, reducing the air that is being blown across the furnaces firebox, this will cause the furnaces safety "fan and limit" control to over heat and shut off till it cools off, then it will turn back on.
If the blower is the one that is shutting on and off, you would notice this at the supply registers in each room, air blows, then stops. This usually caused by really cold air blowing across the firebox, like after the house has been cold - over night, and usually will start operating more along the normal side of things as the home warms up.
Either the blower is moving to much air, blowing strongly in each room, or the furnace has been reducein it's firing rate - derated - a smaller nozzle being installed would be the main cause.... this is the first thing to check,,, if that doesn't do it, it would be highly recommended to have a experienced repair person look at it.
Remember when working in the blower area, please turn off the power to the furnace to save the fingers.
I hope this will give you a game plan.
Have a great evening.
Sincerely,
Paul Gibson
Mar 30, 2010 | Heating & Cooling
I have a magic chef ultra 97 furnace. the blower started making a noise. i removed the blower and blowed the blower out with air and lubed the back bearing with pb blaster. reinstalled blower. the blower...
Feb 26, 2010 | Heating & Cooling
I have 210k btu Magic Chef gas fired furnace and I need a model #
Replace the start capacitor. Take an amp draw on the motor when it starts. Compare that with the rating plate for FLA.
Nov 04, 2009 | Continental Heating & Cooling
I need a wiring diagram for a magic chef furnace
There should bee a wiring diagram on the inside door of the unit, it will show fan speed connections
Nov 01, 2009 | Heating & Cooling
I have an old Magic chef furnace and need to replace the Fan Motor were can I find the fan spec for replacement? It was built in 1987 Model # G8A75DC10-17 Serial# A 10221CKA Forced Air Furnace Categorie I
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Oct 06, 2009 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
