Question about E-Machines eOne 433 PC Desktop
How to remove hard drive emachine - E-Machines eOne 433 PC Desktop
How to take pictures off dead emachine
The hard drive must still be working to get the pictures off. The best thing to do is remove the hard drive from the machine and use either an external USB type case to mount the drive into so you can use another computer to explore the drive or there is a tool that just plugs on to the drive with a USB cable and power supply built in that will serve the same purpose. You must get the appropriate type to match the drive type which could be either IDE or SATA. SATA drives use the small cable and IDE use the wide ribbon. If the hard drive is not working, you would have to get specialized and expensive company to retrieve the data from the drive.
Jan 14, 2014 | eMachines Emachine T1742 Power Supply...
I have an emachines ET1331G-07w.....I cannot boot up windows. My screen is black and reads.......Reads......Reboot and select proper boot device......Tried alot and have no solution?? TY
Usually this error message means the computer doesn't "see" your hard drive. Remove the power cord then remove the side panel of the computer case. Check that the hard drive power cable and data cable are both plugged in firmly to the hard drive and to the motherboard. Plug the power cord back in and try booting up.
Nov 19, 2013 | E-Machines eMachines Desktop PC
My emachines says it cannot find the hard drive and i get blue screen after i restart it
Things to try:
1. Remove and reconnect the hard drive.
2. Remove all USB attached devices. Like other hard drives and anything non-critical.
3. Wipe and reinstall Windows once the hard drive is properly installed.
4. Replace hard drive if bad.
Jan 22, 2013 | E-Machines eMachines Desktop PC
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
How do I replace the hard drive on my emachines PC/
Power down the eMachines computer and unplug it from the power outlet. Remove the left side panel from the computer case by removing the two screws or thumbscrews in the back and sliding the panel toward the back of the computer. Should the panel not move, check to make sure that there isn't a latch or switch on the rear of the computer case that needs to be slid downward in order to remove the panel. Not all cases will have this feature. Locate the hard drive; it should be in a 3 1/2-inch drive bay located beneath the computer's CD and DVD drives. If your computer has a floppy disc drive, the hard drive will most likely be located in a bay beneath it. Check the position of the floppy drive to make sure that you know which 3 1/2-inch drive it is. You should notice two cables plugging into the back of the hard drive; one of these is the power cable that comes from the power supply, and the other is a data cable that is connected to the computer's motherboard. Unplug the power and data cables from the rear of the hard drive, leaving nothing else plugged in to it. Remove the screws that hold it into its mounting bay, setting them aside until you need them for the new hard drive. Slide the old hard drive out of the mounting bay, being careful not to drop it or hit it against any of the motherboard's components. Set the drive aside and pick up your new hard drive, then slide the new drive into the same bay that you just took the old drive out of. Line the small holes in the side of the drive up with the holes in the mounting bay. Secure the new drive by screwing in the screws that you had previously removed, then plug in the power and data cables that you had unplugged from the previous drive. The cables will only plug in when oriented correctly, so you won't have to worry about accidentally plugging them in wrong. Once the cables have been plugged in you can put the side panel back onto the case and plug your eMachines computer in once again. Hope this helps. http://www.youtube.com/watch?v=yQToRwe74P8
Jan 07, 2013 | E-Machines eMachines Desktop PC
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
I need a Emachines D620 SERVICE MANUAL! I'm needint to replace the hard drive in my friends laptop! READ THIS!!! I AM NOT GOING TO PAY 0.01 FOR SOMETHING I SHOULD BE ABLE TO DOWN LOAD FOR FREE!
One DOESN'T need a service manual to replace a hard drive!
You just need to open the case where the drive is. Usually a few screws that are obvious on a cover on the bottom of the units for most laptops. Some have only a couple screws then a carrier slides out.
There is usually a carrier that may require a couple more screws to remove and then up to four screws holding the drive to the carrier.
There often is an adapter plugged onto the drive which you have to transfer to the new drive in some cases.
Just go slow an keep the screws in little divided tray to make sure you put the right length back for each location.
Oct 17, 2009 | eMachines eMD620-5133 Notebook
Panel removal on emachines model e4036
either unscrew in the back, and slide of side or unscrew and open side
Oct 05, 2007 | E-Machines eMachines Desktop PC
E-Machines eOne 433 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
