Need to know how to write three ratios that are equal to the given ratio 6/7
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Multiply both 6 and 7 by the same non-zero number.
For example, if you multiply by 2 you get 12/14, which is a ratio equal to 6/7. I'll let you pick two other numbers and multiply.
Posted on Nov 25, 2013
Diff ratio. On a 1994 toyota 4 runner v6 petrol ??
4x4, 4 cyl, 4.10 ratio, ABS 4x4, 4 cyl, 4.10 ratio, w/o ABS
4x4, 4 cyl, 4.56 ratio, ABS 4x4, 4 cyl, 4.56 ratio, w/o ABS
4x2 (3.90 ratio), 2 wheel ABS 4x2 (3.90 ratio),
4 wheel ABS 4x4, 6 cyl, 2 wheel ABS, 4.30 ratio
4x4, 6 cyl, 2 wheel ABS, 4.56 ratio 4x4, 6 cyl, 2 wheel ABS, 4.88 ratio 4x4,
6 cyl, 4 wheel ABS, 4.30 ratio 4x4, 6 cyl, 4 wheel ABS, 4.56 ratio
4x4, 6 cyl, 4 wheel ABS, 4.88 ratio there are a few options. you will need to figure it out or look at the code panel in the truck. if you want to figure it out. you will need to remove the cover from that axle and count the two ring gears and then divide the numbers to get the gear ratio. for example if one is 40 and the other was 11. would be 3.72. so here is the trick to counting the gears. they are covered in oil so have a pan ready when you pull the cover. and use a marker or crayon and mark a tooth on the gear ring. then count the gears and you will know where to stop when you get back to your mark. the little gear will be harder since its in the back. you might have to turn the wheels and you will need it in neutral and jack the rear end up. as always use jack stands to prevent damage to you or the truck..
Mar 20, 2015 | 1994 Toyota 4Runner
11/8 two equivalent ratios
5.5:4, 11:8, 22:16, & 44:32 *all* have the same ratio. Additional equal ratios can be determined by multiplying *both* the 11 and the 8 by any number. Example (1): "5" 5 x 11 and 5 x 8 for a 55:40 ratio. It is much more desirable to reduce the numbers to lowest whole form - hence expressed as 11:8 ("8 to 11"). A second example using "3/4" (or the decimal equal .75) .75 x 11 and .75 x 8 for an 8.25:6 ratio. Again, whole numbers are preferable unless they get very large.
Jan 05, 2015 | Mathematical Technologies Inc. MTI Tristan...
Pyramid problems in solid mensuration
Look at the problem set up on the screen capture below.
If the pyramid is made of homogenous material you need not worry about the mass (what you call weight) since the ratio of the masses is equal to the ratio of the volumes.
Setting the ratio of volume to be 1/2, and using the ratio of the base areas of the pyramids to be (x/h)^2, you end up with
(1/2)=(x/h)^3
Solving for x, you get x=h/(cubic root of 2)
Mar 02, 2014 | Office Equipment & Supplies
What is a proportion ?
A proportion is an equality between ratios. Let a/b and c/d be two ratios. If the two ratios are equal you can write a/b=c/d. This equality constitutes a proportion.
Oct 01, 2013 | Mathsoft StudyWorks! Middle School Deluxe...
I dont know what a ratio is
A ratio is a division of two quantities that may or may not be of the same nature.
Same nature
You can for example have the ratio of the perimeters of two similar triangles. ratio=perimeter1/perimeter2
Different nature
If an automobilist travels at a constant rate (notice the root RATE, RATIO), the rate of travel is expressed as the ratio of the distance travelled (d) to the time taken to travel the distance. That ratio is called the speed v
v=d/t
Since the ratio involves two quantities of different nature, the speed has a unit derived from the unit of distance and the unit of time; Example v=65 km/h
Other examples:
There is a ratio of 1.45 US $ to 1 Euro. This is usually referred to as the exchange RATE.
The odds of something happening is 7 to 2.
What is really meant when a ratio is involved depends on the context. But what you should remember is that a ratio involves the division of two quantities.
Proportions: The equality of two ratios is called a proprtion.
Feb 08, 2012 | Office Equipment & Supplies
Need to make 50:1 ratio mix. what i have on hand is the poulin 3.2 fluid ounce that makes 1 gallon at 40:1. how many ounces of this mix would need to be used to achieve the 50:1 mix ratio.
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
Dec 28, 2010 | Poulan 2-Stroke Engine Oil - 24 Pack
The ratio of a to b is 2 to 5 and the ratio of b to c is 3 to 4, what is the ratio of a to c
To solve this, you need to multiply the ratios together.
(2/5)*(3/4) = A/C
So (2*3)/(5*4) = A/C
6/20 = A/C
You can reduce that be dividing both sides by 2
3/10 = A/C
Here is an example:
Let X = 3
The problem states that A/B = 2/5
So let A = 2X & B = 5X
A = 2*(3) = 6
B = 5*(3) = 15
Now check the ratio: 6/15 = 2/5. The same as what was given.
Now lets look at the ratio for B/C. The given ratio for B/C was 3/4
Using the value of B that we just solved we get:
B = 15
C = (4/3)*15 = 20
Check the ratio.
15/20 = 3/4
Now we have the values for each of the variables
A = 6
B = 15
C = 20
The ratio of A/C is 6/20
6/20 can be reduced to 3/10 be dividing both numbers by 2
Aug 22, 2010 | The Learning Company Achieve! Math &...
-2/5= /15
If I guessed right your equation should look something like that
-2/5=X/15
A short-cut would be to simplify each denominator by 5, but I will not complicate things for you. I will use the rule about ratios
if a/b=c/d (b and d not equal to 0) then a*d=b*c
Now, with a=-2, b=5, c=X, d=15, the rule about ratios given above can be written as
-2*15= 5*X and
X=-30/5 =-6
Dec 30, 2009 | Texas Instruments TI-83 Plus Calculator
Was given partner 1612 chainsaw and need to know gas/oil ratio please. thanks
50:1 2.6oz mix per gallon or 100:1 about 5 oz per gallon
May 12, 2009 | Garden
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
