Question about JVC KW-AVX810 Car DVD Player
My screen stays black and the blue power button on as well
When i power on wii it stay black and my disc eject work n power button n the led blink blue 1 time but screen stay black plz help me my wife goin to kill me it her wii
have you check the input on your tv , make sure you are at the right input , also check you cables , these cables sometimes come loose
Feb 20, 2012 | Nintendo Wii Console
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Non-responding screen, blue indicator light?
I also got this blue screen,
I fixed it wiit a registry tool, it is powerful suggest you have a try!
Fix blue screen now.
Download blue screen fix tool.
Feb 28, 2010 | HTC G1 Smartphone
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
The screen just went black and i can't turn it off the power button and blue maintenance button just stay on
When the Thinkpad locks up and you can't shutdown the normal way, just press the power button and hold it down until it switches off. If that doesn't work just remove the battery.
Jul 09, 2009 | Lenovo Thinkpad T60 Notebook
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
Sansa e260 screen stays black at power up.
Have you tried holding the menu button down for 30 seconds to reset the devise?
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
JVC KW-AVX810 Car DVD Player Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
