Question about Kenmore 659 Electric Dryer
My kennmore dryer wont start. sometimes when i disconnet the power it seen to work but after a while it wont work and also smells like burn model #66932691
    President:
  • 1,136 Answers
Hi, It sounds like maybe a motor over heating. If you can use it one load and try to restart it, and nothing happens, wait one hour and try again. If it starts, it is probably the motor. Does any of this sound like your simptoms?
Posted on May 08, 2009
I have a Kenmore H2E dryer model 110.87562602. I don't know what happen but smell burn. the panel control is working well but dont start
burning smell good be a lot thing wrong with your dry .if u know how to take front panel off are the dryer may have a bottom access panel be fore u do any thing unplug dry are turn the power be safe are call a appliance repair tech to fix the dryer for u ok .
Jun 13, 2017 | Kenmore Dryers
Dryer smelling like eletrical burning and not working properly
if dont have warranty to be on safe side i junk it. usally to risk to fix thoes things
Dec 29, 2012 | Maytag Dryers
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
We have a Kenmore dryer series 90 model #11066904690 that we started spelling a burny smell. We took off front panel and vacumed out we tryed to use it again and same thing happed and then shut off...
This could be a couple of things. But more than likely the motor has burned out. It could be a wire has burned off, or even the timer has burned. Since you say it "shut off completely", I would have the power cord checked where it connects inside the dryer. UNPLUG it from the wall first! I have seen one wire burn off there from being a loose connection. There is a cover plate you can take off and look inside.
Jul 29, 2009 | Kenmore 659 Electric Dryer
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Dryer wont start when start button is pushed consistantly
check your belt and the motor they both tend to go out
Jan 12, 2009 | Maytag Dryers
Kenmore 659 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
