Question about Sony Alpha DSLR-A350K Digital Camera
My sony camera is giving me a warning message, "unable to use card"
MY CAMERA IS NOT WORKING, IT IS DIPLAYING A WARNING MESSAGE, "UNABLE TO USE CARD" I USED ALL TREABLE SHOOTING INSTRUCTIONS IN THE MANUAL AND I CAN'T GET IT TO WORK.
    Genius:
  • 1,198 Answers
Try another card, and look for scratches or damage on the gold strips on the card. Check the manual to see which way it goes in the camera.
Posted on Nov 26, 2013
welcomejee
  • 10594 Answers
SOURCE: Flashing Acces lamp while using camera.
Flashing Access is sign that memory stick has some problem and mostly it can be fixed if you format memory stick through camera Menu Format Option.
Posted on Jan 04, 2009
SGNath
  • 170 Answers
SOURCE: I have a sony a100. It says unable to use card
What card do you use on the A100? And what capacity? Are you sure you have inserted it in the correct way? Be careful while inserting a CF card because of you insert it wrongly, it can damage the camera. Zooming is done using the zoom ring on the lens barrel. Just twist the zoom ring. Hope you are using the 18-70mm kit lens with the camera.
Posted on Feb 10, 2009
  • 9 Answers
SOURCE: Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Posted on Feb 16, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony A100:put in empty CF cards, says card full, won't format
Might be 2GB card is more then enough for camera hardware o handle. Try 1GB card in this camera.
Posted on Mar 15, 2009
SweetJeanne
  • 9 Answers
SOURCE: I have had my sony for about 2 years and suddenly
It's just the memory card. This error message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Posted on Aug 25, 2009
Sony DSC HX60V camera after taking a picture, when I view it, after a few seconds it disappears and message unable to display comes up
Out of curiosity try different working memory card. See if it works with that one. If it does, then it appears something went wrong with your memory card. If it also does not work see if you can play back a file from memory card 2. If that works then it is a record issue with the camera. In any event it is not a good situation. Sony products are notorious for being difficult to fix and expensive to repair. Hope it is the memory card - they do go bad.
Sep 02, 2017 | Sony Cameras
Good Morning, I keep getting a warning "unable to
This camera will only handle a 16GB capacity flash card the camera Firmware will not allow for larger cards. I ran into a similar problem (different camera) but solved the dilemma with updating the camera firmware. I can only suggest you check out your camera model on the Sony web site for updates if you purchase Memory Cards larger then 16GB. If you have cards under 16GB check make sure your camera is set for memory card and not reading from the Internal memory. Another crazy thing is make sure your clock is working (day date & time) and set correctly.
Jan 10, 2011 | Sony Alpha DSLR-A100K 10.2 Megapixel SLR...
Just loaded a sdhc card and received this message : memory card requires formatting. What do we do?
You'll need to access the camera's menu to locate the format option / command. Make sure that your camera supports SDHC cards. Some older cameras support only the original SD cards. SD cards look identical to SDHC counterparts, but an SD card have capacities that don't exceed 2GB. SDHC (the "HC" part stands for High Capacity") on the other hand are generally 4GB and greater in capacity.
If you are unable to format the card or receive other warning messages, you should make sure the card and card capacity is supported by your particular camera.
Dec 02, 2010 | Kodak Cameras
What do i do when I turn on my sony alpha 100 and it tells me unable to use but I formatted it and it still says unable to use???
It's most likely a problem with the memory card. This message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 06, 2009 | Sony Alpha DSLR-A100 Digital Camera
Mar 15, 2009 | Sony DSLR-A100 K Digital SLRCamera Digital...
Cant get my digital camera to work
hi craig,
first of all backup your data form the card. then format it in ur pc using fat file system. then try to use it in ur camera.
good luck! n pls rate this solution.
Jan 18, 2009 | Fuji FinePix E900 Zoom Digital Camera
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Card error message during formatting XD picture card
The max card size for the camera is either M or H512mb. Try the following website to locate cards for sale www.oempcworld.com
Nov 11, 2008 | Olympus Camedia C-350 Digital Camera
Unable to Use Card
My Z6 does the same thing every now and then.
The only way I can get the message to stop (and that annoying warning chime) is to pop the card in and out real fast with the camera turned on.
It seems as though these Konicas are REALLY picky with the cards, and this is a well known issue. Also, make sure the little "lock" tab is in the "unlock" position.
You can also try taking the batteries out, and holding the on/off button for 1 minute. That resets it back to factory defaults, and clears out any "bugs". Sometimes it helps.
Sometimes using a card reader and manually formatting the card works too.
Apr 06, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Unable to format memory card
You mentioned in your post "the above camera", but I can't find the make/model of your camera? Check on the manufacturer's website to see what the largest capacity card can be used in your camera. Knowing the make/model and searching for the message on the internet can yield better answers to your question.
If this satisfies your question, please rate it FixYa!
Nov 27, 2007 | Cameras
Sony Alpha DSLR-A350K Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
