Question about ViewSonic VT2430 LCD TV
TV CUM ON FOR ABOUT 10 SEC. AND GO OUT
I HAVE REPLACED FOUR BOARDS IN TV AND STILL NOTHING SO CAN U TELL ME WHAT ELSE TO DO. THANKS RODNEY
  • gemagm Nov 30, 2013
    Hi Rodney Whitt, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What boards have been replaced? what kind of response do you get from the TV, pix, sound, clicks, any light on screen, any flashing lights, any lights come on?
    Master:
  • ViewSonic Master
  • 687 Answers
Posted on Nov 30, 2013
Which circuit board on my Smart TV might be broken after a possible lightning strike. There are two main ones. The power is getting to the unit, but I can't get the menus, connections etc to work.
Nobody can predict, what might have been happened to your TV after a lightning strike. Do you thing anybody can? Is any technician have a super-natural power to predict the faults that might have been happened due to lightning (More than 10 Million volts to start on stroke) ? Can you?
Sorry.
Contact the authorized service center. OK?
Jul 29, 2015 | Toshiba Cinema 47L7200U 47" 3D 1080p...
Tv turns off, says no imput then turns back on in 30 sec.
I have repaired this model a few times. You will need to replace the signal board. The signal board, also called the Main Board, has your RF connection, RCA and component Jacks and the HDMI hook ups. You will need to open this TV and find the correct part number, as there are four different boards used in this model. Look for the part number such as 3655-XXXX-0150. The X numbers are important, as they are unique to each TV (same model) but made at different times. In your case do not attempt to replace the eeprom on the main board, this is difficult, and you will want to save this TV anyway. Thanks for asking me, Matt of Martins TV.
Mar 02, 2015 | Vizio E550VL 55 in. LCD HDTV
Lg32lc46 lcd tv cuts off after a while
It sounds like a back-light inverter board fault. Check it. Replace it if needy. Normally, these boards has no repair. Replacement only can be done. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 24, 2013 | Televison & Video
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
Sony 46ex700 standby light blinks 3 times with a break of 2 secs can't get the power on
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV(warranty was expired ofcourse) and found four bulged capacitors. Many electronic companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options . 1. 1.Have it fixed by a professional 2. 2.Dig into your TV, find PSB, Check for faultycaps. If you find some(bulged orleaking) bad caps replace the entire board 3. 3.Remove and then replace individual faultycaps. This takes some solderingskill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
Hope this helps
Dec 10, 2010 | Sony KDL46EX700 46 in LCD TV
Dead, power light flashes 10 times then nothing for 4 seconds then flashes 10 times then repeat. This is after I inserted an SD stick.
Unplug,replug the tv about hour later.Tv will,reset itself,back to factory setting.Should have power now.Still have the same problems.The power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I have a vizio vx42lhdtv10a that has sound but no picture. The screen is just black. Do you know what this could be
You won't believe what happened when held down the power for 10 secs...Nothing.But, I held down the power switch for 10 sec and two caps ( 35v/470uf mc2 and mc3 )on board ( LC420wx7 master ) on the left hand side smoked and the TV started working..So all I had to do was to replace them...My TV is back to life. If any one is looking for answers check these two capsthey could be bulging ..
J73HA
May 19, 2010 | Televison & Video
Hi guys, my Tissot Touch watch has a non sinc problem with the digital and analog time. any solutions? thanks, Rodney
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
Jun 30, 2009 | Tissot T-Touch T33159851 Wrist Watch
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
ViewSonic VT2430 LCD TV Logo
76 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
