Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Visual is distorted: circles are oval not rouns.
How to widen my curtis 42 inch flat sreen top and bottom
Some TV's have a zoom function others do not. The program you're watching controls whether the top and bottom of the screen have black bars and is not the fault of the TV. Widening the picture cuts off a lot of the viewable picture and distorts the image. Circles tend to be oval. If your TV has a zoom function, use it.
Jan 21, 2017 | Top Computers & Internet
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wide screen stretches all my photos
Dec 09, 2011 | Samsung Computers & Internet
Dear Sir the monitor view is like when we draw the circle it will display like oval size so what to do the problem
You need to set your PC video resolution to the native resolution of this monitor, which is: 1440x900 @60Hz.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 22, 2011 | Acer AL1916W 19" LCD Monitor
How do i set my Hager time for outside lights for block of units. It has a dial. The instructions are not clear at all.
I am looking at the 31575 7-day timer manual
1) Set current day and time
The timer dial has numbers 1 thru 7 with oval circles around these numbers
1=Monday
2=Tuesday
3=Wednesday
7=Sunday
The oval numbers are located at 12 noon on each day
Since these numbers are circled with an oval, let's call them oval-1 oval-2 oval-3
Current time is always lined up with black triangle at top of dial
Right now it's Tuesday about 2am
Rotate dial until pointer is near oval-2 ... and then line up pointer with small number 2 (for 2am)
If it was 4pm, you would line up with 16 (using the European 24 hour clock)
If it was 8pm, you would line up with 20
2) Set your on-off times
The dial has segments around outer edge
Segments pushed-in = Timer ON
Segments out = Timer OFF
If you want the timer turned on for 2 days, you push-in the segments between those days
For example you want timer to turn on at 6 pm Tuesday and stay on until 3pm Wednesday
Push in all segments between those times.
Tuesday is located at the oval-2 ... 6pm Tuesday is at the 16
Wednesday is located at oval-3 ... 3pm Wednesday is is at the 15
So push-in all the segments between those two times, and the timer will turn ON at the scheduled time each week.
If you want the timer to turn on and off each day at same time, then you push in the same segments for each day.
For example the timer turns on your outdoor lights at 7PM and turns off at 11PM
Select a day: push-in segments between 19 and 23
Repeat the same for each of the other days and timer will follow same schedule each week
If you need more help, answer back and I will give words of encouragement.
Oct 26, 2010 | Hardware & Accessories
Dell GX260 has distorted video on Dell 19" widescreen. Circles turn into ovals.
Most likely the Display Resolution is not set to a 16:9 display aspect ratio (1366 x 768 for example) if you use a 4:3 ratio on a widescreen, then everything is distorted. Make sure the display is set to the optimal resolution You can look up you monitor's Optimal Resolution here:
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~subcat=54&~cat=3
Jun 16, 2010 | Dell OptiPlex GX260 PC Desktop
Everything is distorted and elongated
You need to set the PC video resolution to the native resolution of this monitor, 1920 x 1080 @ 60Hz for best picture and correct aspect ratio.
You may have to load the driver if you cannot get the PC the let you select this resolution.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 01, 2010 | Acer X233H 23" Monitor
Convergence
There should be somewhere that list the info where to have it serviced or inqire about the set to find parts in your owners manual. Dont what you mean by oval circles at the bottom of screen. Has the set been moved around lately??
May 29, 2006 | Akai PT5492S 54" Rear Projection...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
13 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
