Question about Air Tools & Compressors
Compreesor shut off and wont come back on - Air Tools & Compressors
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
What kind ???
gas ?
electric ?
Posted on Dec 30, 2013
04 bravada airride compressor location
are you looking for the air ride compreesor in is under the back bump on the pessenger side
Feb 10, 2013 | Cars & Trucks
When my ac window cuts off after it gets to the set temp. the compressor keeps running and if you mannualy turn it off the fan cuts off but not the compreesor.
the contact are welded shut. the selector switch has to be replaced if it is a window unit. If its a split system the contactor in the outdoor unit needs to be change.
Aug 14, 2011 | Heating & Cooling
MOTOR IS RUNNING BUT NOT GETTING COLD
you say motor do you mean the compressor, if so is it making any heat if so it says it is trying to work. common problem if so is a frost build up in frezer on back panel keeping cold air to circulate to refrig. from freezer. also check to see if freezer blower fan blowing air. back to compressor, it has large return line should be cold and a smaller high side line usually 1/4 inch and this should be hot if compressor is doing it's job.check cooling motor by compreesor also to much heat will shut it off.
Nov 08, 2010 | Refrigerators
Will car operate if compreesor stops working Will pully freeze up
IF COMPRESSOR STOP WORKING DUE TO LOCK UP PULLEY BEARING YEP PULLEY WILL LOCK UP.IF COMPRESSOR STOP PUTTING OUT COLD AIR DUE TO LOW REFRIGERANT PULLEY WONT LOCK UP.
Oct 11, 2010 | 1991 Buick Park Avenue
Service ride control
rear compressor use to come on often(heard "minor" left rear air leak after stopping and shutting car off). The compressor always came on at start up. after a well loaded family camping trip, the compreesor stopped comming on. when we arrived and I unloaded the cargo, the compressor came on and raised the rear end of the vehicle after unloading the "camping stuff" the compressor came on and re-leveled the car. After trip home and unloaded, the compressor no longer comes on, although car is level and rides nice, but when people used to get in the back seats, the compressor came on and slightly raised the vehicle. I found no blown fuses. would dealer codes say bad compreesor or is there a way to check the compressor? also if I replace the shocks with ones that do not require the compressor, will I be able to ever pull a heavely load car or tow anything without dragging/sagging? any information or insight would be much appreciated... thanks in advance
Feb 04, 2010 | 2003 Cadillac Escalade
Where is inlet port (low) for a/c recharge 134a refridgerant
there are 2 ports, use the large one. This requires the compreesor to run and it may also have a 1/4" service valve wihich has to be opened as well. if too low you will have to use a jumper on the plug for low psi shut off on the bottom of the gizmo. Just did all this on a 93 jeep
Sep 23, 2009 | 2005 Chevrolet Trailblazer Ext
Buzzing compressor
replace the compressor start / run relay
Jul 01, 2009 | Frigidaire FRS26H5AS Side by Side...
Maytag side by side ref. not defrosting
if it didnt go into defrost by jumping across board, i ck that with unit running compreesor on, jumping across the test leads for a few secs. if doenst shut down compressor bad board
Feb 26, 2008 | Maytag MSD2756GES Side by Side...
Fridge powers on but does not cool
Try pressing light blub switch whist doors are open as fan will only start when doorsclosed. If compreesor is running but not chilling it is either the compreesor has gone and wont be pumping or it has lost its refigerant. Hope this helps
Aug 23, 2007 | Frigidaire FRT18B4A Top Freezer...
Air Tools & Compressors Logo
20 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
