Question about Caterpillar American Construction Equipment 1:87 Scale
How to turn up the pump on cat 3406 1988 model
I want to turn the pump up it has been turned down before I got it
Turn load stop and torque stop screws out equily
Posted on Aug 20, 2009
98GMC1500:my catalytic converter is clogged but it won't start Basically I'm trying to see if I have more then one problem Battery is good and I don't think its the altinator It turns over,won't start
If the cat is plugged up, the truck won't start. You can unbolt the cat from the exhaust manifold and see if it starts. Just run a few seconds, as running that way can crack valves if they get hot enough, but running a few seconds won't do it, plus it will be loud as sin. That will allow you to see if that is the issue. An engine can't breathe with a plugged cat and won't start. If the cat is the issue, be sure to correct why it is plugged before spending all that money on a new one. Running rich, burning oil or antifreeze will cause a cat to fail.
Feb 20, 2017 | GMC Sierra 1500 Cars & Trucks
Locate fuel pump
Most cat modles are located in the fuel tank.
Jun 07, 2014 | Arctic Cat T660 Turbo ST Winter Sports
What can i do with a cat 623 pump for a car wash mortor runs & belts turn but pump not pulling water
make sure the inlet is clean, most of these get the hose hooked up without flushing the hose first and end up with grass,frogs and lizards plugging up the pump inlet.
May 08, 2014 | Cat Pump 623 - 10 Frame Piston Pump
Arctic cat 4 wheeler hard to start, keeps turning over and over and then finally starts
weak fuel pump, choke not working ?
Here are the service manuals for all Arctic cat ATVs
Oct 06, 2013 | Arctic Cat ATVs
I have a 1996 Lincoln Town car and while I was driving it shut off. I stared the car and it turned on but another 10 minutes later it shut off again. Could it be a fuel pump problem? Please help.
No its never the fuel pump, ever its always, the 8 dollat fuel filter that has so much dirt in it at 100,000 miles its like puring mud into a cup, or if this model has over 140,000 miles its possible the cat is ****, You can tho check that problem by disconnecting the rear muffler if possible if it runs better great. But you can also notice that a cat is blocked by starting it, when a cat gets blocked it takes more revolutions for the car to start. I would say its that cat, if you start it, then as soon as you put it in gear it would have no power, or it has power but shuts off, and you can restart it reletivly soon like a couple mins, Fuel filter you will just not be able to turn it on for the rest of the day.
Nov 21, 2011 | 1996 Lincoln Town Car
Driving my 2001 kia sephiaall sudden hardly was going 30mph..then when got to hwy..same thing and no matter what gear(5spd)would not accelerate.ck engine lite had been on for awhile and our mechanic said...
HAVENT SEEN VERY MANY PROBLEMS WITH THE FUEL PUMPS ON THESE PARTICULAR VEHICLE . YOU CAN TAKE THE 02 SENSOR OUT AND CHECK BACKPRESSURE WITH A GAUGE OR YOU CAN TAKE THE CONVERTER DOWN JUST 4 NUTS AND SEE IF YOUR ACCELERATION IMPROVES . BUT YES A CAT CONVERTER CAN CAUSE A VEHICLE TO BE SLOW TO ACCELERATE AND KEEP IT FROM GOING TO HIGH SPEEDS DUE TO THE BACKPRESSURE ON THE ENGINE . IF YOU TAKE IT TO A MUFFLER SHOP IT SHOULD RUN ABOUT 200.00 TO REPLACE WITH AN AFTERMARKET . IF YOU HAVE A PO420 IN THE COMPUTER FOR CHECK ENGINE LIGHT THAT IS THE LIKELY CAUSE THIS VEHICLE HAS 2 CATS A WARM UP CAT AND A MAIN CAT IT COULD BE EITHER OR BOTH .
Jan 31, 2011 | 2000 Kia Sephia
Car turns over for a minute then dies
Long list of reasons. Fuel pump, bad coil, bad wires and plug, bad sensors, bad computer, short related to computer or any sensor, bad cat if clogged, bad crankshaft sensor, bad fuel pressure, etc, etc. Without narrowing it down some nobody will be able to tell you what it likely is. I recommend testing for spark and listen for the fuel pump hum for a few seconds when you turn the key to On position (not starting). That could narrow down a lot.
Sep 02, 2010 | Chevrolet Corsica Cars & Trucks
Died going down road like out of fuel wont crank now fuel pump works turns over wont crank
if no check engine lite -check fuel filter,egr valve,cat converter computer
Feb 16, 2010 | 1999 Ford Super Duty F 550
91 vw passat wont start
Change the fuel filter, when the fuel filter is blocked and can cause to cut fuel.
Check also timing belt.
Dec 01, 2008 | 1995 Volkswagen Passat
Caterpillar American Construction Equipment 1:87 Scale Logo
1,056 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
