Question about LG LFX25960ST Stainless Steel French Door Refrigerator
[GML277USRH] Water not coming out
Just got this used fridge from my mother-in-law. It had water at her house but now it's not dispensing. Water valve is spun all the way to the left.
  • Shawn Paul Neckelmann
    Shawn Paul Neckelmann Nov 26, 2013
    Edit: disconnected the water hose and turned the water on. No water coming out! Thanks for your time.
    Problem Solver:
  • 10 Answers
If all the fittings were good when you connected your water line, you might want to go online and find a manual showing the built in filter location. Mine was due for replacement just be fore a move and when it arrived, it had somehow clogged. replaced it and it worked fine. Hope that's all your problem is.
Posted on Nov 26, 2013
5 Suggested Answers
  • 14 Answers
SOURCE: Low pressure water dispensing on an LG brand fridge
First check the pressure into the frig. Sometimes the inlet line can get kinked. The second thing I would buy is a NEW water valve. There only about $20-$30, and not too hard to install. A nut driver and a pair of plyers should be the only tools needed. There are usually 2 water valves, one for the water, and the other for the ice maker. If 1 is bad... the other is next to fail soon, so buy both before to save head aches down the road.
Posted on Jun 01, 2010
  • 489 Answers
SOURCE: I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
Posted on May 11, 2008
SOURCE: water leak in back of fridge for 2 days. All else works fine
It sounds like the fridge water supply line is leaking. Pull the fridge out and have a look. May just need tightening.
Posted on May 28, 2009
  • 1810 Answers
SOURCE: Water dispenser on LG side-by-side not dispensing water
sounds like **** in the lines or a kink in the hose
Posted on Jul 31, 2009
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
My water dispenser will not dispense water. I
you just need to defrost turn off fridg. over night it is frozen in the frezzer door
Feb 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
GE GSS22JFMC when I press the water button it leaks
That's where the water line runs to get to the dispenser. You may have to remove the cardboard backing to see it. The line runs from the water inlet valve. That's where the supply line from the house connects to the fridge. One line goes up to the ice maker and the other goes over to the fridge side where it goes inside the fridge behind the crisper to a reservoir where the water is chilled before it goes to the dispenser. Look for the water coming out when someone else tries the dispenser. Look for a fitting that has come loose.
Oct 02, 2009 | Refrigerators
Rotten smell coming from water dispenser
change your water filter and clean all the lines for water,you must have an algae,mold buildup in there somewhere,and possibly water got into insulation and has startes to mold
Aug 27, 2009 | Kenmore 53632 / 53634 Side by Side...
Water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Aug 15, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
No water but ice is fine
remove the filter and reinstall , it may not have seated into the filter housing it will take a little while to fill the filter cartridge as you hold in the water paddle
you also may have a water valve problem, something in the water valve that goes to the water in the door that is not allowing the water to come through the valve
Apr 24, 2008 | Refrigerators
Water dispenser keeps running
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the problem...Catriver...post back.
Dec 11, 2006 | Hotpoint HSS25GFP Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
113 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
