I have an old two...black/red thermostat wire. Which slot does the black wire go I on the rth6450
  • 407 Answers
Two wire systems are usually heat only systems. If yours is a heat only system, it will not matter which color goes on a certain terminal, just as long as one goes to RH and one goes to W.
Posted on Dec 08, 2013
2 Suggested Answers
mikadot
  • 2113 Answers
SOURCE: My we Honeywell RTH6450 thermostat does not have
Here's the colour of wires someone else used
Posted on Nov 26, 2013
My new RTH6450 does not have a slot for the black wire. Which slot does if go to?
I need to know how many wires you have and what colours they are so that i know which ones substitute for which
Nov 25, 2013 | Electrical Supplies
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
I have the honeywelL RTH111 and also had an old thermostat with only two wires...... the manual says to just hook the wires to the same letter slots as it was in the old thermostat..... i did so but the...
Hook up the red wire to Rh (or Rc if they are jumped together) amd the white wire on W.
For thermostat terminal designation
R - 24 V power in
W - 24 V out to heat circuit
Y - 24 V out to cooling circuit
G - Fan relay
Hope this helps
Jan 21, 2010 | Honeywell Programmable Thermostat Heater
I am replacing old 220 volt thermostat with a programable 220 volt thermostat. There are 6 wires in the box. (3 black & 3 red) There are only two black wires on the new thermostat. On the old...
Hi, this can be confusing. Be sure you have the power off before you wire it, but first you have to have an elect meter. The 6 wires in the box you will only use 2 of them. Cap the other 4 off. Use the 2 that have the correct voltage across them, 208, 220, 240 volts. The new stat is only set up for 2 hot wires 120 each. That will do it. Not to bad. be careful! Use care. Good Luck, Sincerely,
Shastalaker7
Nov 08, 2009 | Heating & Cooling
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Thermostat wires
just put a jumper between rh aand rc and use red, yellow you hook up to y1, white goes to w1, common is either black or blue.
Mar 27, 2009 | Honeywell Programmable Thermostat Heater
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
