Question about Garden
Pressure washer won't stay running - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If it starts then suspect a dirty carb/main jet
Posted on Nov 27, 2013
Brigs n straton pressure washer won t stay running unless you put or keep starting fluid in in
Loosen the carb bowl nut until it begins leaking into the shallow clear glass bowl you placed beneath it. It may take a minute to have drained the water out of the bowl and another minute or so to get some more from the gas tank. With the glass bowl you will be able to see the water in the bottom and gas floating on top of it. When you see the gas on top then tighten the bowl nut and try to crank. (Choking helps draw out water still in carb) Return gas collected. to tank but do not let the water go back in.
Sep 12, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Washer want stay running. I can pull choke and it
mr fixit, I have pressure but it just want stay running
Jul 11, 2009 | Garden
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Pressure washer won`t pressure up
Dear rustrick281,
It seems that your pump needs a good service. The sucktion and delivery valves got faulty. The high pressure seals and the low pressure seals must be renewed. The pistons must be checked for corrosion and cracks. Also the pistons or one of the pistons got stuck due to oncorrect lubrication. The swash plate that drives the pistons could have got loose. So the motor turns and the pump stays dead. So a good examination and service must be done to the pump. To renew all the parts I have mentioned, you must buy a PUMP KIT for you model. The pistons are not included in the pump kit....but hopefuly the pistons are still good. Also the oil inside the pump must be renewed.
Regards,
Fulltech.
May 04, 2009 | Campbell Hausfeld 1800 PSI Electric...
Have you tried adding 30 wheight pump oil,under 1 qrt usually
Mar 18, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
