You must be having the user manual with you. Look for a small pin head sized reset button which should be available in the schematic showing the location about its features. This will restore it to the factory settings or default settings. If it can connected to a PC(it should) then do connect and see what it reads from the camcorder. The site where you candownload a copy of the manual is available at this link: http://safemanuals.com/user-guide-instructions-owner-manual/MEGXON/V5200I-_E.
Hope this helps........................sodeep
Its a clear hardware error in your camera.its not the battery problem.there is a memory ic in your camera.that has stuck in stand by mode.as what ever memory ic commands the camera does.you said in your comment that if you shut the screen it will still not turn off.that means the memory ic is not functioning properly.any how sending it to the service center is necessary.
as they have resetter for these ic they will just reset it and make it proper.
dont void the warranty as its still under warranty.
please do rate the solution.thank you for using fixya.keep updated.thanks
I am guessing that you have tried to resetting the camera by removing the batteries for 15 mins.
Unfortunatly it sounds as if the firmware or flash memory IC for the camera has become corrupted. The only way that this could be rectified is by reflashing the camera with the firmware for that particular model. If reflashing the camera fails or the camera does not get picked up by the flashing software when connected to a pc then the only way to fix the problem would be to return it to the place of purchase or the manufacturer. To complicate things even further ther manufacturer does not list the firmware for that model of camera on their website. Therefore the best solution would be to contact the manufacturer and detail the problem and advise them that it was suggested to try a firmware flash, with a bit of luck they will provide you with the apropriate utility and firmware.
There email address for support is: [email protected]
If the camera is still under warranty then it should be sent off for repair as this is somthing that will be covered under warranty.
In summary:
Try and contact the manufacturer for a flash utility and firmware for the camera, if the flashing fails or they don't give you the software then contact the place you baught it for warranty information. If they fail to give this information then contact the manufacturer via the email above and get the warranty information.
Hope this helps
Try leaving it without batteries for 24 hrs. If there is an internal
battery you'll need to either find it and remove it, or leave it
without batteries for more than 24 hrs.
if that doesnt fix... then there might be a serious problem with ur board.... i know u want to fix it urself but opening the camera inside out will void ur warranty since u say its 8 weeks old.... its better to have a new replaced camera rather than the one which doesnt work and which has already been opened and tamepered with just after 8 weeks...
have a good day
good luck with ur camera
Kindly try to disconnect the power and loose the static charge also check for the battery condition if the problem persists contact the service center as this is very minor hardware injury and will not not take more than 10 minutes at service center,if you are unable to locate the store in fiji do not worry just send it via courier to different service station at different location
actually the defect is mechanical so it requires someone with expertise and proper toolset to fix it but i assure you that it can be solved by local technician
kindly visit this linkhttp://www.globalmediapro.com/content/He...
i have researched a lot in last 2 hrs but no feasible solution is found that you can fix this problem by yourself kindly ask for replacement
OK NOW I M PROVIDING YOU THE LINK FOR MANUAL
http://www.megxon.com.tw/E/techsupp/down...
Remove the memory card and the batterys ..then after 30 sec ..insert only battery and try to turn on...
I removed the battery and sim card then put the battery back after 30 seconds, still did not work.
I need a fix thay I can do without sending to a service centre. Battery is full power, static removed.
The battery has already been out of the camera fo over 7 days.
Mexgxon web site not available
Is it not possible to reset myself.
