Question about Maxtor OneTouch II 300 GB Hard Drive
Burn circuits I plugged the wrong power adapter to this device, and now it doesn't work with the correct adapter. There was an electrical order present shortly after this slip-up.
  • oldfishhook Nov 02, 2007
    burned my circuits the same way How do fix it or pull the dat to anaother drive.
    Can I buy the ckt parts and repalce.
  • 661 Answers
The disk is probalby ok , it's probably just the power circuits for the USB/Firewire adapter that got fried,   if need be you could liberate the disk and use directly, or you could use a different Disk adapter to connect it via USB/Firewire again.
Posted on Oct 11, 2007
SOURCE:
Good day. I bought my Telefunken flat screen and telefunken surround sound. whenever i switch it on there is a buzzing sound. I have checked that all the speakers are in correctly.
1.Try to plug in other outlet with different circuit breaker.
Try to turn off or unplug appliances with motor (e.g. electric fan ,vacuum cleaner etc.).
2. if buzzing sound still exist isolate the ground prong of your power cord if three pin plug are used by using an adapter.
3. if buzzing sound still exist use isolation transformer.
4. if buzzing sound still exist bring your unit to service center.something wrong with your device.
Sep 09, 2017 | Televison & Video
I lost the charger I replaced it with other one same power out let but I can't charge it any more so what could be the problem? What can I do?
Having the same plugin doesn't guarantee that it is the correct polarity (if dc) nor the correct voltage, nor that it is AC when you require DC etc. If you put the wrong adapter on and you are not very electrically inclined... you can blow the power circuit inside the unit.
Oct 22, 2013 | Lowrance iWAY 250C GPS Receiver
The digital read out on my 420 elliptical schwinn system blinks on and off. There is no error code
follow this steps and replace batteries too. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistanc
Oct 01, 2013 | Schwinn 420 Elliptical Trainer
Schwinn 420 elliptical
follow this steps and replace batteries and clean the contacts batteries. God bless you
  • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
  • 2
    Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Oct 01, 2013 | Exercise & Fitness
Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
follow this steps and fix it.
God bless you
  • 2
Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
I accidentally plug my Wii that I got from US from 120v to 220v. I got the converter but I mistakenly plug it to the wrong voltage:(. I heard the poop sound. Did I burn the power adapter or the wii it...
You have most likely cooked the Wii itself, To check connect the correct power adapter to the correct system and in the correct power source ( 120v or 220v ) if it works all good if not you know you cooked it. If you are unable to test in this manner have it checked by a qualified technician.
Jan 11, 2013 | Video Game Consoles & Games
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
Mistakenly plugged maxtor one touch 2 into wrong power adapter
Well Most Likely The Circuit Board Burnet Out Since Its 12V And When Plugged Into A 19V Supply It Will Burn Out Instantly Because It Over Charges The Circuits. So Its Not Possible To Repair Such Damage But You Can Take Out The Hard Drive And Plug IT Into A Desktop Computer And Use It At Home Or As An Online Hard Drive To Store Files
Jun 18, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Maxtor OneTouch II 300 GB Hard Drive Logo
115 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
