My we Honeywell RTH6450 thermostat does not have a slot for the black wire of my red/black thermo wire. Which slot does the black go to?
  • 1 more comment
  • Anonymous Mar 25, 2014
    Does the black wiring on the honeywell lr1620 black wire goes to the g connection on the honeywell rth6530
  • Anonymous Mar 27, 2014
    vulcan heating system. Old thermo had wires labelled as 1 and 3
  • Anonymous Mar 31, 2014
    • 2-wire heat-only system: Connect one wire to R terminal, one wire to W terminal.
    This is what it says for a honeywell Ct87k thermostat. So does that mean it dosent matter which wire goes where?
  • 2,113 Answers
I have an old two...black/red thermostat wire. Which slot does the black wire go I on the rth6450
Two wire systems are usually heat only systems. If yours is a heat only system, it will not matter which color goes on a certain terminal, just as long as one goes to RH and one goes to W.
Nov 25, 2013 | Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
My wife bought a Hunter programmable thermostat to replace an ancient round Honeywell. The Honeywell is simple with the color coded wires simply going to the srews marked those colors. There are 5 wires,...
Normally the common wire is black, but installers can use anything, so you need to make sure that blue came off a "B" labeled screw. The common would normally be labeled "C". You need a simple multi-meter to check, although I have to believe that the instructions with the new thermo would have to cover the hookup and should show some extra connections if truly universal, as it would have to accommodate heat pumps and dual stage systems. With the old thermo mounted on the wall as it was originally with no wires connected, check for continuity between R and each of the other screws. Set thermo for cooling and turn temp down to 60 and see if you get continuity R to Y, set fan to on and see if you get continuity R to G, set thermo to heat and see if you get continuity R to W. If you just have a single wire that runs to the contactor in your condensing unit, and one wire for the heat, then the red is power from the transformer in the furnace, green is for the fan on all the time during cooling, yellow for the AC contactor, and white to bring on the heating cycle, IF ALL are single stage (only one setting for heat, cool, or fan that is either on/off). Check for continuity between R and B on each possible setting. If you get no continuity or greater resistance than on the other screws (when checking R to B), set meter to VAC and see if you get 24 volts between red and blue wires - the wires coming out of the wall and not the thermo screws. If so then you have a simple single stage for both heat and cool system. If you tape off the blue wire so that it can't contact anything in the new thermo then hook up the other wires as you state and see if everything works as it should. The blue wire in that case is a common that is not needed in your new thermo as it has its own internal battery power and does not need the common to power it from the transformer. Some systems actually use 2 transformers and the common does not run to the thermo as the other leg of each circuit is terminated elsewhere, but another wire does. If so, you will not get the readings above and you may need to do some rewiring - this is very unlikely.
Apr 25, 2017 | Hunter Fan Company 7-day programmable...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Blower stays on with new themostat
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
