The Dry cycle leds on my DSXH47EG1WW flash within the first 20 seconds after starting, they flash for about 2 seconds, go out, then about 10 - 15 seconds flash again for a second, then on the third flashing, the entire dryer stops, and all the mode leds flash. Sometimes it beeps, sometimes not...suspect a control module, but the cost prevents my replacement. Any ideas?
Some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
With an error code. This can reset the system. First unplug the washer and wait a 5 minutes then restart it. If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange! Usually it corrects some error problems if they are not serious. Or they are sometimes just a glitch. Let me know how it works out.
How old is the appliance?
Please remember to leave a rating before you sign off.
The LEDs begin to flash if one of the following malfunctions occurs:
NTC open (the LEDs flash in sequence from right to left)
NTC short-circuited (the LEDs flash in sequence from right to left)
If the START button is pressed for more than 20 seconds while a cycle is in operation all the LEDs flash.
If the microprocessor identifies one of the conditions listed above, operation of the dryer is interrupted; the LEDs continue to flash in order to warn the user of the malfunction.
If the error is eliminated, the dryer returns to normal operation when the programme selector knob is turned to RESET and the drying cycle is re-selected.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
So this answer is on the same topic of a 2005 Ford Focus keyless entry remote. There is no way to "reset" the code from the vehicle, however you can reprogram an existing or program a new keyless entry remote to your Ford Focus by using these simple instructions:
*** THERE ARE 2 POSSIBLE PROGRAMMING PROCEDURES. ***Procedure #1
Note: Obtain all remote transmitters for this vehicle.
Note: Do not depress the brake pedal during procedure.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
Within 20 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 4.
Within 20 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 3. For all other remotes.
Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Procedure #2
Note: Obtain all remote transmitters for this vehicle.1Fasten seat belts and close all doors.
Turn ignition from OFF to RUN 4 times within 6 seconds, with the 4th time ending in RUN. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
Turn ignition to OFF. Acoustic signal will sound and system warning lamp will illuminate to confirm programming mode.
Within 10 seconds, press and hold any button on the first keyless remote. Wait for acoustic sound and warning lamp to flash (confirming programming) then release button on remote. Wait 2 seconds but within 10 seconds repeat step 4. For all other remotes. If you only have one remote then continue to step 5.
Turn ignition to Crank or wait 10 seconds to end programming mode.
Telephone: Fax: VAT Registration No.: Infrared remote control NOTE: Infrared emitter can be seen at front edge of key. System operation Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Programming When Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction. How Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates. NOTE: LED illuminates for approximately 5 seconds. Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds. NOTE: A maximum of 4 keys can be programmed. Fig. 1 Radio frequency remote control System operation Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds.
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system. Programming When Key added or replaced. System malfunction. How Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds. NOTE: A maximum of 4 keys can be programmed.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
System operation System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again. Programming When System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced. NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system. How NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment. Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Programming When Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction. How Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates. NOTE: LED illuminates for approximately 5 seconds. Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3-5 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds
The 'Start' & 'Pause' LED's will flash together to indicate the
error code. You have to count the flashes within each 15 second period
to get that error code. The start and the pause LED's will flash
together at 1Hz (i.e 1 flash per second) within that 15 second time
frame, then will continue and show again within another 15secs and so
on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Press these buttons in succession, within 5 seconds: high temp wash, air dry, high temp wash, air dry. If the sequence is entered properly, all of the control panel LED's will illuminate simultaneously. Once this happens, press the cancel button twice. Now you should run a complete cycle again. If the dishwasher actually has a problem, it will fault again (means the unit isn't heating properly). If not, it's business as usual.
