Question about Electrical Supplies
My new RTH6450 does not have a slot for the black wire. Which slot does if go to?
  • 2,113 Answers
I need to know how many wires you have and what colours they are so that i know which ones substitute for which
Posted on Nov 26, 2013
I have an old two...black/red thermostat wire. Which slot does the black wire go I on the rth6450
Two wire systems are usually heat only systems. If yours is a heat only system, it will not matter which color goes on a certain terminal, just as long as one goes to RH and one goes to W.
Nov 25, 2013 | Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
I recieved a ds lite with water damage and the four odd wires on my ds lite motherboard all come off does any one have a diagram of where the wires might go thanks please help
from the tom screen there should only be 2 wires 1 black and 1 white. The white wire is the mic that plugs straight onto the board, and the black wire which plugs onto the wirless insert which attaches onto the board. the other 2 wires could be loose speaker wires if there is another black and a red wire, other than that could you explain a bit further what the wires actually look like.
Jan 16, 2010 | Nintendo DS Lite Console
Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
May 09, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
INSTALLING NEW HOOD VENT RE CIRCULATING NO DUCT
The white which has the longer slot is the negative and the black wire which has the smaller slot is the positive ( hot ) wire.
Nov 23, 2008 | Hotpoint  Standard Range Hood
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
