Washer drum loose and banging
It is a kenmore 110.20422.990 it sounds like a jackhammer when it spins. The drum is loose. What is going on and how do I fix it?
    Genius:
  • 1,198 Answers
There are springs that support the drum, open it up and check them out.l
Posted on Nov 26, 2013
barkencoa
  • 3463 Answers
SOURCE: drum is loose and banging on hotpoint aquarius wf541
This sounds like a classic case of main drum bearing or drum support failure, it is a major repair and not really a DIY repair, unless you are coversant with w/m's
It involves a complete strip down and in some cases it is neccessery to to have to replace the drum as well.
The cost of the parts involved is well in excess of £100.00,and it really is not an economical repair.
I think you would be better off buying a new washer.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
SOURCE: my washing machine bangs terribly
Check under the washing machine to see if there is any grey dust. My machine made so much noise on the spin that i could not use it. The solution was the front brick had loose bolts. When I tightened them up, I had no more problems
Posted on Apr 09, 2009
  • 572 Answers
SOURCE: loose inner drum
your bearing is gone. needs a new tub assembly. its pricy
Posted on Feb 05, 2010
jumptrout51
  • 3361 Answers
SOURCE: While on high spin the washer makes a loud banging
It is OFF BALANCE. Re-distribute the laundry and re-start.
Posted on Jan 10, 2011
Testimonial: "Thanks! Should've known..."
Sounds like loose pieces banging around during spin cycle
could be loose coins, pens, or other non-removed pocket objects.Check your drum very closely particularly around the bottom.
Aug 06, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore 500 bangs when spinning
Sounds like the bearing in the drum has bust but shouldnt be too expensive to replace.
Nov 19, 2013 | Kenmore 24902 Top Load Washer
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
When the washer spins the drum sounds like an airliner it also just started making a banging sound I can feel the banging on the right side of the washer
Try load it a little lighter and spread the clothes more evenly (in other words so that the weight is not all on one side.
Sep 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
