Question about Boating
How to remove power trim motor mercury 150 black max
2 Suggested Answers
  • 86 Answers
SOURCE: 1992 150hp merc black max and hydraulics won't work, sounds like a sick animal.
On the bottom of the trim/tilt cylinder there is a big white slotted head screw usually located on the right side. Turn that out about 3 turns. Have someone help you manually lift the engine and while it is up tighten that screw back up and it should stay. From there you can check your trim lines and check the Cylinder for leaks. Also check to make sure that there is no water in the system. Once the engine is all the way up just engage the tilt lock and you will be able to do anything that you need to without fear of the engine bleeding back down.
Posted on Aug 03, 2009
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
Boat manual
it normal would be on top of the motor were all your electrical comes into the motor .you would see 50 amp fuses next to them there should be 4 round black contactors that have all your wires from your tilt motor and your trim motor connected to them. but if it still works its not the contactors .try this have some one pull up on the outdrive while you hit the switch . if it goes up its your tilt motor has water in it or was damaged by hitting something . water damage is fixable only if its fresh water .salt water you need not waist your time . buy a new one .and if it is fresh water ,if you no how to take stuff apart and putt it back togeather again...the tilt motor need to be cleaned ,up and new seal kit put in it .it should work fine again .
Jul 28, 2014 | Transmission & Drivetrain for Mercury...
How do i replace the light switch that isn't the pull out to turn on type in a 1994 mercury capri
You need to remove the black plastic dash trim that the switch is in. There are several screws above the instrument cluster, and several behind the black trim pieces on either side of the steering wheel. Its a pretty easy job, those trim pieces just pry out, and snap back into place. Once loose. remove and replace the switch...good luck...Chris
Nov 07, 2011 | 1994 Mercury Capri
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Feb 14, 2011 | 1997 Mercury Grand Marquis
How to replace 12v charger socket on dash in ford 150 2006
Start by removing the center trim panel around the radio. It is held on with 6 spring clips. Open the ash tray, and pull on each lower corner and then work your way up. Spring clip locations are circled in black in the picture below.
The 12 V power port on the dash, I use 1 hand to help release it from behind while pulling on the front part. It snaps into place.
The Cigar lighter on the center trim panel, Ned to unplug the harness,( easiest to remove the black trim panel by pushing the tabs ) and push in the plastic tabs, and remove the socket from the front .
That covers both, let me know if you need additional information
Thanks
Nov 16, 2010 | 2006 Ford F-150
My tilt on a yamaha ox66 200 motor quit working,what should I try first?
Step 1:
Operate Trim Switch Do You Hear Clicking Sound In Engine
Yes ,No
Step 2:
If Yes Check Wiring To Power Trim Motor are All Cables Tight
If No Then The Trim Relay And Or Trim Switch Is Probably At Fault
Step 3:
,Remove Three Large Color Wires Going To Power Trim Motor Black, Blue And GreenConnect Black Direct To Negative Battery And Blue To Positive Battery Motor Should Trim Up ,Remove Blue Then Try Green To Positive Battery, Motor Should Trim Down ,If Nothing Then Trim Motor Is At Fault If Works Then Trim Relay/s Are At Fault
Jul 03, 2010 | Boating
How do i change a blower motor in a 1999 mercury cougar
Blower Motor Removal
  1. Remove the footwell upper trim panel (passenger side).
    • Remove the pushpins.
  1. Remove the blower motor.
    1. Disconnect the electrical connector.
    1. Lift the securing tab, turn the motor approximately 30 degrees counter-clockwise and remove the motor.
Jan 10, 2010 | 1999 Mercury Mountaineer
May 23, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Blower motor fuse is located 99 mercury cougar
SECTION 412-04: Control Components 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Blower Motor Resistor Removal
  1. Remove the upper footwell trim panel (passenger side).
  1. Disconnect the blower motor resistor electrical connector.
  1. Remove the blower motor resistor.
May 06, 2009 | 1999 Mercury Cougar
Boating Logo
107 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
