Question about Garmin APPROACH G6 GPS
The battery wont recharge - Garmin APPROACH G6 GPS
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
My sons rca 10.1 tablet wont power up.....right before this happened it was froze on the start up screen and wouldnt power off. I let the power run down hoping then I could charge it and it would power up...
Jan 19, 2015 | Tablets & eReaders
Bush mp3 player mpk431 wont recharge battery
may be the charger is bad or the battery
Jun 03, 2012 | Audio Players & Recorders
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
THE BATTERY LIGHT STAYED ON AFTER CHANGING THE STARTER. THEN THE RADIO AND ALL THE GAGES WONT WORK. CAR WONT START NOW?????HELP
Recharge the battery. Then after it is recharged it should start. Then have the alternator checked.
Mar 09, 2011 | 1999 Ford Expedition
2006 dodge durange wont start tried to recharge
Some times battery's are beon recharging that recharge wont do it, after you recharge battery turn your lights on, if very dim or dont come on, battery is no good replace it, also try to start it it if lights go off, replace battery.
Jun 23, 2010 | 2006 Dodge Durango
Battery wont recharge how long do they last and can i get a new one? battery model bat-09. Player is pdv-709 9" portable dvd player.
The litium battery should last u about 3 and 3 1/2 years.The minium used about 4 1/2 hours a day,about 3 times a month.Tries Websites Amazon.com,Ebay.com should have this Litium battery.
Apr 06, 2010 | Durabrand PDV-709
The battery died on my 03 diamante. when i tried to recharge it the car alarm started and wont stop to allow the car to keep a charge?
Only Recharge the Battery with both the Cables: Positive and Negative removed from the Battery.
With the Charger OFF the Battery - Reset your Alarm turning it OFF.
Then Disconnect the Battery completely.
Never Recharge a Battery while it is still connected.
Jan 20, 2010 | 2003 Mitsubishi Diamante
Camere jammed and wont turn off and retract
Install new batteries.....really! They will just up and die when your camera's on and then there's nothing else you can do. If you have rechargeables....swap them out for any fresh batteries just to close your camera...then put your recharged rechargeables back in. Or put them back in and recharge on your camera dock.
Mar 13, 2009 | Kodak EasyShare C613 Digital Camera
4th Generation ipod wont recharge
there must be a virus problem..a bbetter solution is put it on n let all the battery get over..and then recharge it from the beginning.
maybe ur connection is not proper. try putting the wire properly.
Feb 23, 2008 | Apple iPod nano
Garmin APPROACH G6 GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
