Question about Cobra CPI 1000 DC to AC Power Inverter
88 ac volts at receptical
I have a cobra cpi 1000.hooked to my truck dual altenator gmc.I have 14.9dc volts coming in and only 88 ac volts coming out.unit is a2010 with little use.low voltage will cook things
  • James Donor
    James Donor Nov 25, 2013
    Watts / Volts = amps 1000 / 120 = 8.3 amps.where did 100 amps come from.A copra 1000 watt needs 12 dc volts to make 120ac.So why am i only getting 88 ac volts at the plug
    Genius:
  • 1,198 Answers
Sounds like the transformer is done. Have a big switch on the DC side, to turn it off when not in use. Being on all the time burns it out.
Posted on Nov 26, 2013
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Cobra inverter
should probably connect it straight to your battery or you are trying to use something that requires too much power.
Sep 04, 2014 | Cobra 12 Volt 2500 Watt Power Inverter...
User manual
yes it will charge it is built in invertor
Jun 29, 2013 | Cobra CPI 1000 DC to AC Power Inverter
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
2006 CPI GTR 150 battery keeps draining
Hi, Anonymous first perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for a drop in amperage then get out your test light and track down the short in that circuit.
5. Hook up a voltmeter to the battery and start the engine, if meter falls below 9.0 volts while cranking you need to perform a proper load test on the battery and replace if necessary.
6. With the engine running at 3600 RPM, the battery should read 14.3-14.7 volts if not continue tests.
7. Unplug the voltage regulator from the alternator at crankcase by the front of the primary cover.
8. To test voltage regulator go to https://www.youtube.com/watch?v=F8EjV0IjW9Q
9. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace the stator.
10. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace the stator.
11. With the voltmeter set on AC scale, both leads touching alternator pins meter should read 16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace the rotor.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Tracing battery drain
My motorcycle or scooter battery wont hold charge How to test the charging...
http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
http://scooterbbs.net/board/DCForumID11/5035.html
Nov 20, 2012 | 2006 Cpi GTR150
Getting LUP code when turning unit on
typically means it isnt getting enough power.
Aug 23, 2011 | Cobra CPI 1000 DC to AC Power Inverter
M/n cpi 1575 I've had my inverter installed in my
it indicates an overload situation
not enough information provided as to voltage supplied to the inverter and the voltage of the grinder
examples are for 110 volts ac with a current draw of 4.2 amps the wattage is 462 watts or for 240 v ac with 4.2 amps the wattage is 1008 watts assuming that it is 240 volts and the inverter has a maximum ate of 1000 watts then it is overloaded and circuit protection is cutting in
check the wattage of the inverter and the wattage of the ac units you use and if there is not a 25% difference in favour of the inverter then it is an overload situation
Jul 27, 2017 | Cobra ® Power Inverters
I am looking 4 a 50 amp fuse that came with it, can't fid it can i use a 40 amp? this is four a 1000 cobra
if your are looking for a 50 amp fuse i have found my self going to a care audio place they have the bigger fuses on had to to amps and so on hope this helps good look
Jan 08, 2011 | Cobra CPI 1000 DC to AC Power Inverter
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Cobra CPI 1000 DC to AC Power Inverter Logo
116 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
cwradio73
Bill Boyd
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
