Question about Ovens
New world 60edom
When more than one ring is working it sends the other heating rings constantly heat up and they can be turned off but not turned down
4 Suggested Answers
  • 11 Answers
SOURCE: I have a Whirlpool Envoy free standing cooker,
Give it to me! Mine doesnt work at all.
Posted on Oct 16, 2009
SOURCE: Moved into a house with a New World 60EDOm fan
Hi please would it be possible to have the manual for the Newworld 60edom, I have a problem with one of the rings on it seems to come off and on. Can not locate the manual anywhere.
Many thanks
Posted on Mar 06, 2010
  • 643 Answers
SOURCE: Hi, I have Schott Ceran
The switch under that knob is bad. It's called an infinite switch. it runs around 5.00 at partsselect.com
Posted on Nov 11, 2010
Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Oct 01, 2016 | New World Ovens
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Zanussi hob can't turn off full power on one ring
the regulator is faulty you will have to fit a new one fairly easy task let me know if you want more help
Apr 17, 2012 | Zanussi Ovens
My oven is not heating up but the fan is working - any ideas?
I dont know your model but generally the problem would be that the ring element around the fan has blown or less likely the thermostat has failed.Normally if you can see the light on the control for the oven temperature control light up and can hear a click from it as you turn up or down the the thermostat should be ok.You will have to get the ring element out and check with a multi-meter if it is blown and replace.
Hope this helps.
May 20, 2010 | Ovens
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
Moved into a house with a New World 60EDOm fan oven and electric cooker, but we are missing the manual, would it be possible for us to be sent one?
Many thanks
Nov 29, 2009 | Ovens
2 of 4 ceramic rings do not respond to lowering the heat setting
You need 2 new temperature regulators fitting.
Quite a common problem..
Thanks
Plz rate solution
Dec 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Element / burner / hob is overheating on an electric oven
If three of the rings are not responding to adjustment, then I would say yes, you have faulty regulators;It is a fairly straightfoirward job to replace if you know how to access the controls
Dec 05, 2008 | New World E70DOa Electric Double Oven
NEFF Hob
change the relay
Sep 21, 2008 | Ovens
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
