Onkyo htr640 My Onkyo HT-R640 surround sound system works well in DVD mode, but when I switch to TV mode I get no speakers to work. The speaker test button works & all speakers sound connected, I do see on receiver "AV- No Signal" Can you help
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
mlapres
  • 757 Answers
SOURCE: connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
Posted on May 09, 2009
My sound on Onkyo HT R 548 stopped working
If this is a Surround Sound System you can check channel and audio tone levels using the remote. Check remote for a receiver button followed by Test button. Check manual for test instructions.
Dec 30, 2014 | Onkyo Audio Players & Recorders
Very dull sound from the 4 rear spekers on my 7.1 set up for the ONKYO 802. This happens for the satellite input for tv channels, is this normal that I will only get surround sound via a disc or other...
Your basic setup through the Onkyo establishes the base levels of each speaker channel with test tones. The tones should also sound pretty much the same from speaker to speaker.
How a given surround mode works with a given input would be documented in the manual. Even stereo sources can be proecessed into some form of 7-speaker output.
"ONKYO 802" is not unique. Are there letters?
Jul 20, 2011 | Audio Players & Recorders
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
No sound from Surround speakers of my onkyo reciever
Check speaker wireing make sure all positive and negative connections are correct. What cable are you running from tv or DVD player.check to see that wireing is correct on receiver for sorround speakers. Run audysee sound calibrator set up. Make sure correct settings for sorround sound in bluray player/DVD player
Sep 13, 2009 | Onkyo HT-S990THX System
ONKYO HT-S780 B SPEAKERS
Your symptom sounds as though you may have to turn off any surround sound settings that you have selected in the other modes.
Most amplifiers use the surround portion of the amplifier to power the B channel speakers.
Since you have sound when using the radio portion, I would try turning off the surround mode. For example try turning the amplifier to just stereo and see if that gets the B channel speakers to work
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 22, 2009 | Onkyo HT-S780 System
Surround sound speaker outlets are not working
Hello, I am sorry about your issue. If the speakers work on other terminals then it sounds like a problem with the receiver. It would need to be serviced or traded in. Please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jun 24, 2017 | Onkyo HTR500 Receiver
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Getting home theatre sound AND sound from TV
i dont think you are suppose to have the tv speakers on with the theather systems speakers on because of the magnectic field can cause your tv speakers to mess up.
Jan 30, 2008 | Samsung HT-X40 System
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
27 people viewed this question
 Grubhead
Grubhead
