Question about NexxTech FM Transmitter
Need user manual
I require a user manual for my Nexxtech FM stereo transmitter Mod# 2610510
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
Iwave fm stereo transmitter
This is a device that "Sends" FM stereo & Transmitts Radio waves, and sends sounds/music speech etc, over the airwaves to a suitable reciever an the same "Channel" You can hook up say your Ipod to it and say tune your Car radio to the "Station" it sends on and listen to ya compilations, in the car, thru the car stero system. The radio just "Sees" it as another strong station.
Jan 24, 2010 | Pyle PIFMDK6 iPod Car Stereo FM...
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
Sep 18, 2009 | Bose Indoor/Outdoor Speakers (Pair) -...
Stereo removal guide for a 2005 Chrysler Crossfire convertible
Gently pry the surround using a plastic tool. There are two catches on the top and two on the sides at the bottom.
With the surround off, you will see the screws holding the stereo.
If there are preamp jacks in the back, it is eaxy to add an aux post using an adapter cable. If there are no input ports, you will need an oscilloscope to find the preamp circuits inside the stereo. Only do this if you know what you are doing and are good with an oscilloscope and soldering iron.
Aug 11, 2017 | 2005 Chrysler Crossfire
How to hookup an IPOD to a pioneer avh-p6500 car stereo
If your car stero has a stereo audio input connector then you can plug a cable in the headphone on the IPod and the other end of the cable into the stereo audio input on the car stereo.
If you don't have an stereo input on the car stereo then you can buy a FM transmitter that is powered by the car's cigarette socket, connect the IPod to the transmitter, switch on the car radio and tune it to the FM station that matches the FM transmitter.
You can now listen to your IPod from the car radio.
Jan 26, 2009 | Pioneer AVH-P6500DVD Car DVD Player
User Manual Required
try www.jvc.com click on mobile---- then click on support----- click on user manual for you model
Aug 30, 2008 | JVC AM FM CD DET FACE CAR STEREO
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
NexxTech FM Transmitter  Logo
76 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
