Question about Ovens
Hob too hot
Hobgets too hot out of control
Knobs on hob above the oven getting very hot. Guess heat must be escaping from the oven. Any suggestions?
Try putting a layer of insulating materials between the Knob and the oven. That should help.
Aug 10, 2015 | Ovens
Hotpoint ew91 halogen hob wont turn off
the control may have shorted. replace control(behind the knob).
Sep 10, 2012 | Hotpoint Ovens
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
Hi, 3 of the 4 oven hobs have failed to work on the 720ef. only 1 of them heats up now. when you turn the knob of the failed hobs only 1 out of the 3 makes the click noise but still doesnt heat up,...
Normally the 720ef is the oven, the hob is a separate unit and in my case is a STOVES 600G gas unit. Your unit may have a built on hob but the handbook for the 720ef does not detail this. In my case the hob ID is on the lower right hand side of the unit.
I think you will find that the elements may have failed but you will need to identify the hob to ensure correct replacements. Normally the element rating is on the base of the element. The handbook will tell you how to take the thing to pieces. It is possible that the hob element controls have failed but unlikely for all three or it may be a combination of both parts. I think you may have to contact an electrician to test everything to sort this out.
Mar 08, 2011 | Stoves 720EF Electric Double Oven
Our Simpson Esprit hob has terrible heat control. We are burning everything, even on low because the temp is too hot, but then when we try and boil pasta on a high heat we cant seem to get it even to...
I am assuming the cooktop is electric. Are the hotplates the solid type, coil type or beneath the glass. Are these new to you or have you been cooking with these for a long time?
Mar 06, 2011 | Ovens
Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
Hi
I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
it is the pan which will get hot, the ticking may or may not be the pan heating up.
Try it with water only in the pan and see if it works.
Dec 20, 2010 | Hotpoint Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
I need replacement control knobs for my hob-can
In your browser bar type in-------WWW.SERVICEFORCE.CO.UK.
Follow the links in the drop down menu, and you should be able to order the parts you require.
Please rate my solution.
Thanks.
Nov 07, 2009 | Zanussi ZBF360 Electric Single Oven
Removal of hot plate hob
usually you have to take the side panels off and hobtop is secured by screws to frame
Sep 24, 2008 | Ovens
Ovens Logo
11 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
