Question about NAD C320 2-Channel Amplifier
No volume control
Hi all,
   I've got a NAD C320 Amp hooked up to a NAD C521 CD Player and a pair of B&W DM600 S3s.
   When I play something on it, the speakers just blare really loud and the volume knob doesn't change a thing (the volume won't go up or down). The bass, treble, and balance knobs also have no effect on the sound.
   The lights are on, but no one's home. What do I do?
  • gcd07 May 09, 2009
    There's no volume control on the CD player (NAD C 521BEE). Is there another way I can go about lowering the volume on it or the amp?
    Sergeant:
    Champion:
  • 255 Answers
Lower the volume of the cd player
Posted on May 08, 2009
  • Alan  Serna
    Alan Serna May 28, 2009
    you can lower the volume through the remote.and yes through the amp, too
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Jun 20, 2012 | NAD C320 2-Channel Amplifier
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
Wotcha, i've just taken amp out of storage, has'nt been used for a while cant get volume to work properly the sound goes from speaker to speaker and up and down in volume whilst crackeling a lot as...
One way of proving it ISN'T the amp circuitry is to remove the pre-main jumpers and jack in a source that has its own volume control (or try a CD that starts really low) because this bypasses ALL the amps controls. If it sounds ok (albeit LOUD) I'd suspect oxidized contacts on the controls. Turn it off and vigorously operate all controls a zillion times to wear through it. In mosty cases it's the unused controls that fail because they never get wiped. Maybe a shot of contact cleaner on those you can access.
http://www.overload.it/supporto/643/manuali/NAD-C350.pdf
Oct 15, 2011 | NAD C350 2-Channel Amplifier
Hi, I have a Rotel 1050 receiver that I am trying to hook up to a NAD 2400 THX amp. I do not know how to "bridge" the connections so that the Rotel amps are not disabled. Any help is appreciated.
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
Apr 10, 2010 | Rotel RMB-1095 Power Amplifier
NAD C320 system sounds like a cheap, tinny tranny
Let's distill this down to its simplist configuration. FM source, stereo.
BTW, a search for NAD 440 only brings up a C440 >>>Tuner<<, no receivers. Are you sure about that model number? The only receiver model numbers with x40 on the NAD website are the C340 and C740, neither of which has a link to a manual (go figure). I have the C740 manual, so I'll use it for a loose reference.
If it still does what you're describing in a basic configuration and the volume control seems to affect it like you belatedly mentioned, I'd suspect a noisy volume control or some other control in the receiver (like a rarely used Tape Monitor switch) that is always there in the circuit but may have oxidized contacts and responds sometimes to burn-through.
Set the volume at a medium setting and repeatedly operate every switch, knob and button (one at a time) to gauge its effects on the sound. You may find one is the culprit. Then it's a matter of accessing it for a shot of contact cleaner.
If you have jumpers between Pre Out and Main In, it might be a good idea to reseat them, too.
Mar 23, 2010 | Audio Players & Recorders
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
PreAmp to Amp problem
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Nov 18, 2008 | NAD C320 2-Channel Amplifier
Nad c520 high pitched ringing
Hi, From your description, it sounds as if the noise is coming from the circuit that controls the display backlight. If I recall correctly, the C520 has an EL backlight just like the C521 (which I have one of). On the front of the circuit board, there should be a little yellow trimmer potentiometer that controls the brightness of the display. It may be that the noise will go away if the brightness is turned down some. If  the noise varies as you turn the controller, but doesn't go away completely, the backlight may need servicing.
Aug 06, 2008 | NAD C521 CD Player
Nad 310 amplifier VERY QUIET
take audio out from tv and insert it in aux in in your amp.
Jul 15, 2008 | NAD C320 2-Channel Amplifier
NAD C320 2-Channel Amplifier Logo
314 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
