Question about Freezers
Kenmore model 253.26432100
This unit stopped freezing after we moved. It has a digital thermostat, which is flashing "E", which I take for Error? I can set the temperature control from 1 to 5, but "E" resumes on the display after about 10 seconds. I haven't checked any components. Hoping someone may know what the "E" code means, which may indicate a specific fix.
SOURCE: digital control settings
I have the dlefield maual if you talking about the digital defrost/temp adj
Posted on Jan 13, 2009
SOURCE: Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Posted on Apr 07, 2009
  • 358 Answers
SOURCE: I need to know what the numbers mean on the
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Posted on Oct 06, 2009
SOURCE: My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
Posted on Sep 29, 2010
  • 910 Answers
SOURCE: Kenmore elite upright freezer, model
OFF indicates that the Temperature Control is switched Off.
Pressing the Up or Down Buttons should change the display back to the Temperature Display and allow you to set the required Temperature.
Posted on Jun 13, 2011
Kenmore frost free freezer model253.24452100 turns on but does not freeze. The compressor kicks over then stops. What might it be?
Is the compressor still receiving 120VAC when it kicks off? Kenmore Freezer Temperature Control Thermostat 216788000
If not, replace the cold control. If yes, install a URCO410 hard start kit and listen to it purr... Relay overload capacitor URCO410
Mar 22, 2016 | Kenmore Freezers
My frigidaire freezer is not freezing....the hi temp light is on. The model # is LFFU17F5HWH.
is the unit running, can you hear the compressor , it the freezer fan running check to make sure no wires have been pulled off
Apr 22, 2014 | Freezers
My kenmore model 19502 freezer is not freezing
Have the same freezer bought the warrenty glad I did services tech said that he knew the porblem before he came to fix it compressor locked up at 7.9 amps he said this is an issues with 99.9 percent of this model. Light was on flashing but food would not freeze. Sears will replace for me they are giving me a diffrent model number. I had no power surge or nothing of that manner. Faulty appliance. A recall has'nt been issued... but it should
Oct 13, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Has power but does not freeze
About the only things that can be replaced on a chest style freezer are the thermostat, and the starting device for the compressor. if you know where the control is then thump it fairly hard to see if the unit comes on. If unit comes on then you need to replace the thermostat. (control and thermostat are same thing). now if it has the digital display on the door of the freezer do not thump it. Only the newer freezers have those though. Hope this helps
Mar 02, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
THE GREEN POWER LIGHT FLICKERS, AND COOLS ONLY WHEN THE FAST FREEZE POWER BUTTON IS TURNED ON
This sounds like the freezer stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit. Whilst sourcing the part, put a standard socket timer on to the plug to stop the unit running all the time.
Dec 09, 2009 | Magic Chef Chest Freezer MCCF5WBX
Kenmore upright - wont defrost, runs continuously and wont freeze properly
well don't be surprised, these electronic fridges run on dc electronics also and are sensitive to power surges. is this the freezer because there's no thermostats just the limit control. use a surge protector on the outlet to protect the electronics. if your still having problems get the limit sensors changed first (if applicable). if you want to go the safe way, I'd consider buying a surge protector and connecting it to the power.you can e-mail me with any questions @ hvac.tech7872pr@gmail.com
Jun 14, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Stopped running
try putting on fast freeze. if it starts up this means thermostat is faulty. get back to me if you want
Apr 04, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
54 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
