the unit was getting close expiring and i let it run out but one day it powers up with the sirius logo and beeps and that as far as it go's and the units never been drop or abused please HELP
-   Like the others said, my radio shows the sirius logo but never loads the menu and beeps. In addition, I have always had problems with the power supply losing connectivity. I purchased my radio in Dec. of '05 (followed the Stern show) so I had the older models before the FCC reduced the strength. Also, I have an older car that will have trouble setting up a direct connect so I don't want to give up the stronger FM transmitter.-   orem123
Oct 16, 2008
-   just beeps with "sirius" and the dog, but never turns on-   ascheinbach
Oct 13, 2008
-   Same problem here. I have had his radio for nearly 4 years with no problems until now. I used it in my house as it had a strong FM transmitter that the newer radios don't have. Guess I'll have to buy a newer model...... -   craigbear
Oct 01, 2008
-   same problem with teh screen and beeping it really sucks-   Guest
I'm assuming that it repeats the Sirius logo and beep at a periodic rate and never loads up to the tuner interface. My radio suffered the same fate. Unfortunately, it is dead and out of warranty.
Sanyo only offers a 1 year warranty. If your radio is still covered, they will replace it. Otherwise, you're SOL and will have to buy a new radio.
i found holding down the menu button when the sirius logo is displayed, then turn it off and then on again-it seems it will run as normal(exept my antenna signal is sooooo **** it still doesnt work....Sanyo sux
I've spoken with Sanyo Service twice regarding this issue. The first time I was told that the solution was to power the unit off for 1 hour, and that it was something that could be serviced. The second time I called, when I asked what the service procedure was, I was told they don't know what causes the problem. Hmm...
In any case, I managed to get the case open. After removing the faceplate, take out the four screws in the front. Using a small screwdriver / pry tool, pop the case off at the FM out port. BE CAREFUL! The FM transmitter is soldered to the front of the case, so don't move it around too much or you'll lose that nice, strong FM transmitter. Once you locate the connection for the FM transmitter (a small wire), you can open the case such that the two halves lay next to one another.
Once inside, you'll see another metal box that contains what I believe is the main chipset (Agere). More screws here. Once you take the screws out, you can lift off the metal case. Here's where I suspect the problem lies. There is a cheap heatsink pad in here that, I suspect, over the years has degraded to the point where it no longer conducts well. I cleaned the top of the chip with IPA and put some new thermal compound inside. I have not yet removed the pad as I did not have an appropriate thickness piece of something else that I could use to replace it. I then reversed the process to put the case together.
My radio is still funny, but it seems to work better now. Since the weather is now cooler, when I have problems with it, I hold it out the window or in front of the air conditioner and it comes back after a couple of minutes. I also disabled the blue LEDs so that the heating inside the unit is minimized. It conceivable that there's a bad solder somewhere, but I didn't see anything that stood out. If I continue to have issues, I plan to go back in at somepont and remove the pad, replacing it with something else (copper foil? another pad?), but until then, I'm still in business, even if somewhat diminished capability. I've got a lifetime subscription that I'm fighting to avoid a transfer on, at least for a little while...
Sanyo CRSR-10 Trying to find one for parts. I need the adapter from the back. Where you plug the...
(More)
Sanyo CRSR-10 Trying to find one for parts. I need the adapter from the back. Where you plug the power/speaker/antenna in. Not at Sanyp / Sirius / APac Parts or partstore. Thanks v_Jamese@hotmail.com
My car always has a signal in my office parking lot and my driveway. Yesterday on the way home it...
(More)
My car always has a signal in my office parking lot and my driveway. Yesterday on the way home it was working and then i stopped at a client. I got back into my car and no sound. I tried changing the stations yesterday and that got me sound for about 10 minutes, then nothing. My dead zones last like 10 seconds and it's sunny yesterday and today. Its an older radio, but it works great (until yesterday), and it doesnt' need the antenna booster to get maximum sound. On the radio (sportster) it shows the signal at 3 bars on the bottom left corner. I've tried resetting it and the antenna is new (about a month or two)
My radio is stuck on acquiring signal tried pulling the plug used the indoor/car power cord. I use...
(More)
My radio is stuck on acquiring signal tried pulling the plug used the indoor/car power cord. I use the car antenna and the home antenna but nothing still stuck on acquiring signal. What can I do besides throwing this out (subscription goes until January)??
I cannot get the ac adapter to work in a new power outlet installed on my motorcycle. The adapter...
(More)
I cannot get the ac adapter to work in a new power outlet installed on my motorcycle. The adapter works fine in other power outlets and the new outlet on my motorcycle powers up other devices just fine. Can I do something, besides the already tried twisting and other fine changes in position of the plug, to make it work? Your help would be greatly appreciated. thanks, Merrit
All of a sudden one day my CRSR-10 unit lights up with the Dog and Sirius word on the screen and then beeps about every 10 seconds but never actually gets to loading the menu.
It did load one day after beeping for a while but now it will not load up to the menu at all.
