Question about Husqvarna Garden
Husqvarna t435 oiler problem - Husqvarna Garden
3 Suggested Answers
  • 4088 Answers
SOURCE: husqvarna 345 bar oiler
Remove the bar and chain. Start the engine and observe the oil delivery port in the side of the engine case. At a fairly fast speed, the oil should ooze out of the port. If little or nothing, check the pump, lines, and in-tank filter. If ok, clean the bar drive-end holes of sawdust and dirt, especially the small passages that go from the large holes out to the chain groove. Clean the entire groove and the outer end sprocket. Reassemble and test the oiling by running the bar tip at speed in front of a piece of cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Posted on Apr 09, 2010
SOURCE: oil leaks from the bar oiler when not inuse on Husqvarna 268
Try THICKER oil like straight 30 weight
Posted on Apr 10, 2013
How do i adjust the oiler on a husqvarna 51 no oiler screw
It is a non-adjustable pump so you can not make adjustments to it.
Feb 11, 2015 | Husqvarna Garden
Can you install a Husqvarna 350 adjustable oiler in the Husky 240 ?
No, the oiler from the 350 will not fit the 240.
Jul 13, 2014 | Husqvarna Garden
Husqvarna 350 oiler swap ?
Not as far as i know, ive checked both parts manuals and they both have two different part numbers which would suggest they are different.
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
Husqvarna T435 chain gets loose after few cuts
New chain does loosen after a few cuts. Retension and you should be ok after that if tensioned properly. Check that it is oiling properly by giving it a free runand you should get a line of oil spraying off. Hope this helps
Oct 05, 2013 | Garden
How to adjust automatic oiler on 455 husqvarna
I'm sorry, but I'm not aware of any adjustments that can be made to the oiler. Just make sure the ports are clean so that the oiler doesn't get clogged and that the oil lines are all clear and you should be good.
Nov 13, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 235, my oiler has quit working. I pulled the clutch assembly & cleaner the oiler gear but still no oil, resavoir is full
If you spin the oiler with the when it is desmantled does any oil come threw? (if so then the drum may not be linking to the oiler properly) also check the screw that determins how much oil is coming threw is turned up. And check the filter in the bottom of the oil tank is not blocked
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
hope this helps a bit
Apr 21, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 340 oiler not working
Hello again Rudy.
Please reply below (Add Comments) with the serial number of your saw then I can investigate a little further.
You can reply even when the question is closed. I am not certain how but I get email notification of your reply when done correctly. If equipped the oiler adjustment is below the crankshaft on the clutch side. Look up from the bottom. On the side of my 359 is an icon of a link of chain with a drop of oil above it. The oiler adjustment is aft of that and can only be seen from the bottom of the saw. The manual I saw said 3 position only with CCW (3 - 18 to 20" bar) most oil. Forcing it beyond the stops causes a lot of problems.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2007/HOUS2007_1150331-95.pdf
Page 36
Is your serial number is between 07 18##### and 08 17#####?
Page 5 item 1 shows location of the serial number. Not all newer saws have an adjustable oiler. Please reply below.
Lou
Dec 18, 2009 | Husqvarna Garden
Garden Logo
118 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
