Question about Dryers
Ge dryer manual dvlr223e
Hit start button and just buzzes
    Scholar:
    New Friend:
  • 81 Answers
Make sure your cycle is properly selected with the timer and that the dial knob isn't broken. It will make that noise if you try to start it when the cycle is set to off. Otherwise, you might have something stuck in your blower wheel. Try spinning the drum by hand and if it doesn't move, there may be a restriction causing the motor to hum.
Posted on Nov 27, 2013
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE Dryer making buzzing noise
It does not look like there is an access panel from the back side on this model, but you may be able to try this: Remove power to dryer. Take screw out that holds the end of the exhaust pipe to the back of the dryer and pull out the metal exhaust pipe. Now you should be able to look in and see the end of the motor and the belt. Release the belt and turn the motor shaft by hand. If it turns easily, the drum supports slides are pobably shot ( WE1M333) and possibly the part that holds them (
WE3M26) which causes exsessive drag on the drum. If the motor shaft does not turn easily, hope you have a sock or wash rag stuck in the blower wheel. If not, motor is bad. To get at the blower or the other parts you will have to take the screws out holding the top down to the front of the dryer, then remove the screw on each side near the top holding the front on. Lift the front slightly and remove. You don't have to take off the wires to the door switch. Parts I listed are supporting the drum on the top side. If you need more info do an "ask me" question.
Posted on Sep 03, 2008
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
heatman101
  • 43501 Answers
SOURCE: GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 29, 2010
Wont start.buzzes.unplug to turn off
Possible unbalanced load in the washer. I have found this to be the case in other types of top load washers. Just redistribute the load the try again. If this works, washer is doing what it needs to do to keep from spinning madly out of control and extending its life!
Feb 25, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore 70 Series Extra Capacity dryer wont start
there is several problems it could be the bearings in drum could be bad or there could be a sock or other item locking up drum from turning.
Nov 06, 2013 | Dryers
When I press the start button on my GE DPSR610EG4WT profile dryer it only makes an electrical buzzing sound and will not turn on or start. What causes this?
The buzz is probably coming from the control switch drive motor. If it is not turning the switch, the dryer wont run.
murf427
Aug 02, 2012 | GE DPSR610EGWT Electric Dryer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
I have a GE dryer that makes a buzzing sound when I try to start it but it wont start. I just finished a load and now it wont work.
sounds like you have a bad motor. you can try taping down your door switch or having someone hold it down for you and then hit the start button while giving the drum a kickstart with your hand clockwise. If the unit starts up and gets running then you have bad start windings on your motor. Just replace the dryer is not worth putting a motor in. Hope this helps.
_MJ_
Dec 15, 2010 | Dryers
GE Heavy duty Dryer will not start when ''start button'' pushed...will make a loud buzz, starts for anything from 10 -20 seconds if I keep finger on the button then goes off I have to keep returning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | GE Dryers
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Dryers Logo
64 people viewed this question
Top Dryers Experts
