Question about Alesis MasterLink ML-9600
Disc failure while to burn a CD on the Alesis Masterlink ML-9600
After mastering to the ML-9600, sometimes it takes many tries to burn the CD, It never get's out of the finalizing mode, makes a rumble type noise and eventually says Disc failure. I use quality blank CDs. After many tries, and many reboots, it ends up working. Is there a way to fix this issue?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
The Alesis fitted with a standard computer CD drive, there's an online list somewhere of compatible drives. Take the lid off, unscrew the current drive, and replace. It sounds like the drive is faulty. Online instructions all over the place on how to replace these drives in PCs - it's no different in the Alesis
Posted on Jan 05, 2014
SOURCE: masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
Posted on Jan 18, 2009
MNfisherman
  • 11896 Answers
SOURCE: Alesis Masterlink ML 9600 won't power up.
After reviewing the repair and owners manuals. I have come to the conclusion that there is a short in the power supply board. Your drives should be fine. I don't know off hand how expensive it is to fix in your area. I would say approx $200
Posted on Jan 19, 2009
  • 37 Answers
SOURCE: Alesis ML 9600
make sure that you have a good power source and cables first.
it seems that a filter cap is not doing what it is supposed to do. which one, i don't know.
you could try to format the HD and update the latest firmware/OS and see if that does the trick. next , if you have new/er harddrive, you could switch it out.
keep us posted
dave
Posted on Oct 13, 2009
micromatikal
  • 2777 Answers
SOURCE: My Alesis Masterlink ML 9600
Yikes, that is pretty much as bad as it sounds. That means you have major hardware failure inside the device, specifically the control board of the player. This is basically the main piece of the device and is quite expensive to replace, many times the board itself costs more than a new unit, let alone and service charges to put it in. Unfortunately you are going to be far better off just replacing this unit.
One thing to try, to see if somehow it is just a temporary glitch (I doubt it is, but worth a try) is to just unplug it from the power source for a good 5 minutes, then replug it in. Hopefully that will "kick-start" the board back into gear and get it working at least for a while again. Definitely worth a try.
Thanks,
Tim
Posted on Oct 10, 2010
  • 125 Answers
SOURCE: I bought an Alesis Masterlink ML 9600 for my
When you press Create CD, the Alesis will try to create the CD from the WHOLE of the current playlist that you have selected.
Is there a track of less than 5 seconds in this playlist that you've perhaps forgotten about? If so, delete it from the playlist, and you should be able to proceed
Posted on Jan 11, 2012
HDCD Reset CD Eject Failure
Replace the CD drive. There's a list of compatible drives online. There's instruction online for replacing CD drives in PCs, the Alesis is no different.
Sep 26, 2013 | Alesis MasterLink ML-9600
Hello,my masterlink records red book cds just fine. with or without dsp on tracks. my problem is when i am burning cd-24, they sometimes burn and finilize without dsp. however with dsp on tracks i get cd...
All I can offer is that something about your DSP is stretching the parameters of the Masterlink too far. What DSP are you applying? Is it subtle DSP, or gross manipulation?
Aug 30, 2013 | Alesis MasterLink ML-9600
Ml 9600 cd player stoped working (disk error)
remove disc and try another and or clean the disc--if all now will not work either a dirty of a failed Optical pickup in the unit.
Apr 24, 2012 | Alesis MasterLink ML-9600
Alesis mastering cd recorder manual ML-9600
Consult the Alesis website, alesis.com, or google it.
Oct 08, 2011 | Alesis MasterLink ML-9600
Ml-9600 wont burn cd , it says insert blank cd then the system cancells the creating process
It won't write to a previously-used or partially-used CD, only a totally blank CD-R
Sep 13, 2011 | Alesis MasterLink ML-9600
NO OS on Start Up, Insert OS CD? I don't have one...Web Link to burn on my Mac and then try to fix? Steve Glenn Seattle WA Master Link ML-9000
alesis.com has/had links to download of OS. Download to mac, burn CD as an ISO image, insert CD into 9600 and follow prompts to install
Aug 25, 2011 | Alesis MasterLink ML-9600
Masterlink says load OS
go ahead and try it. reload the os. it is avail on the alesis site.
the o.s. may be corrupted and a reflash is what it needs. if the issue persist, the HD may need to be replaced.
you will need to burn an image cd for the masterlink. most cd programs can do this. if you cant, send me an email.
bcssr@charter.net
dave
Nov 09, 2009 | Alesis MasterLink ML-9600
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
Would pay for an OS Disc, I am unable to get the download to burn properly
Is this what you want.
Masterlink OS v2.21 For Windows & Mac
MasterLink allows new software to be installed via CD-ROM. If you have a PC or a Mac with a CD-burner, you can download the file below and create an updated CD for your MasterLink.
Mar 13, 2008 | Alesis MasterLink ML-9600
Alesis MasterLink ML-9600 Logo
80 people viewed this question
Top Alesis Televison & Video Experts
Electro Med Services...
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
