Washer keep filling with water - Washing Machines
    New Friend:
  • 32 Answers
You will need to provide more information. It could be anything from a bad pump, bad board, leaking valves, etc.
Posted on Nov 25, 2013
jsrock516
  • 5911 Answers
SOURCE: GE washer keeps filling with water.
It sounds like you have a bad fill valve assembly. Normally the valve opens and closes by an electrically activated solenoid which is usually controlled by a pressure switch. However...IF the diaphragm that closes on the valve is broken, has a hole in it, cannot close all the way due to an obstruction, or if your water pressure is too low, the valve will remain open and water will leak by. Since you didn't mention any problems with the hot water side of the valve, I would suspect that water pressure probably isn't a problem. Turn the water off and remove the hoses to the fill valve on the back of the washer. Inspect the cold water side for any obstructions and/or check for any damage to the valve itself. If you don't find anything obvious, replacing the fill valve will probably correct your problem. I hope this helps.
Posted on Sep 10, 2007
  • 45 Answers
SOURCE: washer won't fill
On the drain valve there must be some dirt that does not let the valve close or the valve must be defective and needs to be replaced. By the way you did not mention the make of the washer.
Posted on May 11, 2008
  • 53 Answers
SOURCE: My kenmore top load washer keeps filling, watere
the fill valve is bad or there is a hole in the tubing that attaches to it, this tube goes from the pressure switch to a bulb on the side of the tub only air pressure goes through this tube one small mouse bite and it is damaged
Posted on Jul 09, 2009
  • 343 Answers
SOURCE: Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Posted on Apr 18, 2010
TheMobilian
  • 8220 Answers
SOURCE: My washer fills with water and keeps filling
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Posted on Jan 07, 2011
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Apr 18, 2010 | LG WM1812C Front Load Washer
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Aug 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer won't fill
May 11, 2008 | Washing Machines
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
