Question about Savin C9020 Black Developer Unit Cartridge Genuine
Trying to copy checks I am getting solid black page
When copying the page comes out SOAKED in black ink
The cartridge or Toner is splitting out more ink.... Remove the cartridge Clean it and place it again.
Oct 30, 2012 | HP Office Equipment & Supplies
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
In copy or scan mode, the page is almost all solid black
The scan assembly has gone out. Parts are not available except the entire scan assembly, I can get you a part number and price if you like.
Jun 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Printer prints solid black block at end of page
You have to replace the white tape, connecting the scanner sensor with the printer PCB. 26642b8.jpg
Nov 23, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
Copies are solid black
first try scan doucument to the pc if it is also come black then change scanner assy,
if problem is not found then replace logic card
Jul 20, 2008 | HP Photosmart C3180 All-In-One InkJet...
Copies & Faxes come out solid black
Sounds like a charge problem, check the clutch that moves the charge roller to contact the drum. The clutch is on the back of the machine. Brad
Aug 17, 2007 | Ricoh Aficio 250 Copier
Savin C9020 Black Developer Unit Cartridge Genuine Logo
23 people viewed this question
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
George Mclaughlin
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
