Question about Hobart A200 Stand Mixer
Hobart mixer A200 motor hums or stuck
The motor will not turn it only hums. changed capacitor but it still hums without turninig
bigg t
  • 640 Answers
SOURCE: hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Posted on Feb 19, 2008
ricardok45
  • 135 Answers
SOURCE: motor worm gear hobat a200
Harry, if you're confident that you can take it apart and repair it yourself, then do the following. Go to www.hobartservice.com website. Register, and when you've been admitted to the site find the discontinued products section on the left hand side of the page, click on it, then select the Food Machines Group, then select Mixers. Make sure that your ML# is covered by the document.Select the file numbered A-200 Parts List F-6728. pdf. Look for the ML#. Once you've selected the document, go to page #9, there you'll find the exploded drawings for the A 200 transmission parts. If you look at the whole document (15 pages), you should be able to see what needs to be taken apart to get at the worm gear.
If you're not sure you can do this...Then don't do it. But if you do, check all bearings, springs and gears for excessive wear and replace as necessary. Hobart techs do this stuff every day. For someone who has not done this kind of rebuilding before, it can be a long and expensive learning curve. Good luck. If you find that this solution has been helpfull to you, please rate it. ricardok45
Posted on Jan 05, 2009
  • 6 Answers
SOURCE: hobart A200 mixer motor worm gear
sometimes you read of other problems and solutions and it puts you at the edge of your seat. in this case of changing the worm gear on the A200F was cake. when you drop the lower end (3/4 acorn and jam nut), pull out yoke (speed select handle) the center transmision shaft and gears pull right out.worm gear easy to change at this point. if you can change a motor bearing, then you can do this job. Note: change seals and bearings as needed,check all gears,keys and spacers for wear and if you go the mile take gears off drive gears, these are the 2 smaller trans shafts put in lath if you have accsess to one if not roll shafts on flat surface to see that shafts have no bends in them. Also remember when you put the bottom back do not over tighten the jam nut,hold and lock acorn nut, should spin free and have about .016 to .030 movement up or down. Lay out all part on cardboard the way they came out. should go back together easy.
Harry Ooooooooooo
Posted on Jan 13, 2009
SOURCE: Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
Posted on Jan 17, 2009
SOURCE: Hobart mixer A200 Rotation
I have a hobart a200 20qt mixer. the flat bitter is scraping the botttom of the bowl. The shaft looks little bend and i think it is and that is what's scraping the bowl at the bottom on one side only. the whole bowl is not being scraped. it used to work like that and now it does not work at all. the motore is running but the gears are not turing the mixer. Before the first geard stoped working but the other two were okay, now none of them work, but the motore is working.
Posted on Nov 10, 2009
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Hobart A200 won't start
If the gearing is all free to move and you replaced the motor capacitor that only leaves the motor. If you can remove the motor and test it "out of the gearing" that would confirm it. You have wired the capacitor correctly and used the correct one? Just asking! Are you sure the gearing isn't jammed up?
May 13, 2014 | Hobart A200 Stand Mixer
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Our Hobart A200 Mixer only turns on for a few seconds. It has a lot of saftey features that were not familiar with. How do i get to work properly.
It sounds like you get a degrading or bad start capacitor (locate right behind motor cover (see fig 22, page 12 of part catalog, cost $13). Here how you can check if your machine still work properly: 1- Rotate the agitator shaft manually to check for any binding. 2- remove two wires from the capacitor. 3- Use a small jumper, connect one end jumper to one wire and touch the other end jumper to second wire 4- As soon as motor start, remove the jumper. Good luck, If your ,machine have never have preventive mainternance it is a time to do so. (atva)
Apr 19, 2010 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
Hobart a200 wont turn untill i turn doe hook then will rotate is this a motor problem?
Sound's to me like the start switch in the motor is bad or sticking.Does the motor hum?
Apr 21, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
I have a Hobart a200t industrial mixer which isn't running properly. When turned on, it just hums, and the gears don't move. I have been searching online and cannot find a free troubleshooting guide. I...
Hi, it is hard to determine exactly what the problem is without seeing it, however, that mixer usually uses a capacitor to help start the motor, and a switch, or relay, that are in the back of the unit. You probably will not find any troubleshooting guide, Hobart does not give up information easily. You can take it to an electric motor repair shop, and they will easily be able to tell which of those is the problem, and will be reasonable in price. Your other option is to contact Hobart locally for service assistance. Maybe one of the other Hobart techs here can help you out more.
Mixer not working
I think your problem may be with the start switch in the motor.Let me know.
Jul 22, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
48 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
