Question about HP Pavilion dv9000z Notebook
Monitor won't turn on
No blue light, nothing on the screen & no sound.
    Problem Solver:
  • 5 Answers
Your video chip over heated and popped up. This happens when the cooling paste runs out and dust bunnies start to form inside the fan. This is a comment problem with the DV2000, DV6000, DV9000 and a few other models HP has. They're a few youtube videos that show you how to reflow the video chip yourself. You have to take the motherboard out and heat up the video chip. Heating gun is the best way. You'll also need some cooling paste and don't forget to clean out the fan from dust bunnies. It will last maybe around 3 months to a years before you have to do it again. Also buy a laptop fan. Hope this helps
Posted on Nov 26, 2013
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
My laptop sounds like it's running but the screen is black and the green power light and the blue wifi light is on. If I disconnect the battery it sounds light it's off but the green and blue...
If the screen is black but it's making all the right sounds that you'd normally get when the computer was working, then you can, in all likelihood, connect the NC8000 to an external monitor, do a cold start, and work off an external monitor for now. And you have also isolated the problem to be "up top" (the screen area)
If it just turns on but outputs nothing to the LCD or the external monitor, then it's probably trouble. I'd remove the memory and reseat them. If that doesn't make a difference, then you'll have isolated the problem to be "down below" (the motherboard, in all likelihood).
Hope that makes sense...
Sep 05, 2011 | HP Compaq nc8000 Notebook
I have an LG-1934S. The screen won't turn on - power button continues to flash blue. Checked cords - unplugged plugged back in - blue light keeps flashing. Hit keys on keyboard and on mouse - nothing....
To find out where the problem is, you will have to try this monitor with another PC or try another monitor with this PC first to narrow down the problem.
Please post back after what you find out so we can help you further.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 22, 2011 | LG W1934S-BN 19" Monitor
Well I have a Gateway Laptop Model MS2274 and it won't turn on. The light of On/Off is blue so it's on, but the screen remains pitch black. I connected it to recharge it and the light turns on too....
Try connecting an external monitor and see if your see anything. If you can then most likely your LCD monitor on the laptop is dead. Also try FN+ the monitor toggle key to see if you can get video.
Jun 20, 2011 | Computers & Internet
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
HP Pavillion f1903 monitor, power light turns blue, no display
sounds like the flourescent backlights are burnt-out--very expensive to replace and dangerous
Mar 14, 2010 | Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
HP vs17X monitor blue power ligth blinking, nothing on screen
Sounds like a power surge fried the electrical connections inside.
Jul 14, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
